XFI Cam
Old Nov 28, 2007 | 08:54 PM
LT4hotcam's Avatar
Default XFI Cam
Has anyone run the XFI cam 230/236 576. 570. 113 LSA cam. Is it a good cam?
Thanx chris
Old Nov 28, 2007 | 09:09 PM
LT4hotcam's Avatar
my bad guys. i put the wrong size and i put the lift also.
thanx
Old Nov 28, 2007 | 09:47 PM
StealthFormula's Avatar
thats the cam I believe that emerica4601 has and he dynoed like 360ish cam only with his 6 speed.
Old Nov 28, 2007 | 11:59 PM
Akira_X's Avatar
You think that cam would pass CA emissions with a tune?
Old Nov 29, 2007 | 12:08 AM
95Lwind05's Avatar
I was actually looking into going with this cam as well...Id like to hear some more people chime in that have this cam...My car has stock heads and is pretty much full bolt ons, and was curious to see the drivability with this cam, and dyno numbers.
Old Nov 29, 2007 | 10:19 AM
aboatguy's Avatar
Looks like your talking about the 280 XFI I had it in my car for a little while about 2000 miles or so. It idled nicely and had some power, however, I pulled it and went for a custom cam of about the same duration with a tighter LSA and a lot more lift and never looked back.
For a stock engine it is probably a little too big and you'd be better served by something in the CC305 - 503 range. I know that your stock valve train won't like the lobes.
Old Nov 29, 2007 | 10:40 AM
No, the cc503 224/230 is hard enough to get to pass
Old Nov 29, 2007 | 11:50 AM
95Lwind05's Avatar
Ya with a 1.6 rocker thats almost a .615 intake lift. Would you have to upgrade anything other than the valve springs?
theres got to be more than just one or two people using this cam.
Old Nov 29, 2007 | 12:43 PM
fordeater's Avatar
the lift the xfi's are shown having is with 1.6's
Old Nov 29, 2007 | 12:50 PM
Akira_X's Avatar
I thought so... I was thinking about the 503, but would the xfi 218/224 be better because it has more lift?
Old Nov 29, 2007 | 02:13 PM
LT4hotcam's Avatar
I have the 1.6rr, and a rebuilt block, so would i just need to change the springs?
Old Nov 29, 2007 | 02:59 PM
95Lwind05's Avatar
That makes sence, I was thinking thats alot of damn lift..summits website is a bit misleading they advertise the lift with "Lift with Factory Rocker Arm Ratio".
Does anyone know of anyone using this cam in a car thats a DD?
Old Nov 29, 2007 | 03:17 PM
kinglt-1's Avatar
I would not use this cam with out porting your stock heads, bottom line!!! Your not going to use the cam to it's full potential with out increasing head flow.
Old Nov 29, 2007 | 04:01 PM
355z28's Avatar
I was looking at an xfi cam to *** well a comp guy said use a part #07-466-8 the specs are 218/224 lift is 570 on the intake and 565 on the exhaust on a 113. I did a search and all i found was a guy that asked about it, he said he was going to get it, but never posted results. Any info??
Old Nov 30, 2007 | 06:42 AM
aboatguy's Avatar
The advertised lift is with 1.6s. I used the 280 XFI in my DD for a couple of thousand miles and went to a custom cam with a lot more lift and a tighter LSA.
It idled well, but I had AI 190s then. For stock heads I'd look in the cc 503/305 range. Bigger is not always better.
Mike
Old Nov 30, 2007 | 08:32 AM
96LT1355Z28's Avatar
I've had this cam for about 1000 miles. I'm happy with it so far, good idle, great driveabilty. The Summit web site is a little misleading but when you click on the cam read the info at the bottom of the page and it says specs are with 1.6 RR's. My cam card says .576IN/.571EX, 230IN/236EX @ .050, 113 LSA. My car has ported stock heads and intake 52mm TB and made 371 rwhp and 351 rwtq. I may make more power with a custom cam, but now I trying to get my 10 bolt replaced! As for emissions test's I have no idea we don't have them in Missouri,,,yet!
Old Nov 30, 2007 | 01:30 PM
95Lwind05's Avatar
Originally Posted by 96LT1355Z28
I had this cam for about 1000 miles. I'm happy with it so far, good idle, great driveabilty. The Summit web site is a little misleading but when you click on the cam read the info at the bottom of the page and it says specs are with 1.6 RR's. My cam card says .576IN/.571EX, 230IN/236EX @ .050, 113 LSA. My car has ported stock heads and intake 52mm TB and made 371 rwhp and 351 rwtq. I may make more power with a custom cam, but now I trying to get my 10 bolt replaced! As for emissions test's I have no idea we don't have them in Missouri,,,yet!
are your heads just ported or are they ported and polished...if ported do you have any flow numbers?
Old Dec 1, 2007 | 09:34 AM
I know they're ported but I'm not sure if they were polished, I think so. Here are the flow #'s from the local shop who did the head work. I kept the stock valves and used Comp 918 springs.
Lift - IN - EX
100-61-51
150-93-74
200-120-100
250-150-117
300-178-128
350-182-150
400-218-159
450-233-168
500-245-178
550-255-181
600-264-185
The shop who did the work said the numbers in the 250 to 450 range are what matter. Most heads are advertised at max flow but you're valve is only open at that height for a very short time. Because of this aftermarket heads sometimes look better than they really are, especally considering good porting is around $700.00. However I'm sure if you had the money you could port aftermarket heads and get some serious #'s from them, I wouldn't know I can't afford it! Hope this helps.
Old Dec 1, 2007 | 09:46 AM
96capricemgr's Avatar
Are you kidding?
Polishing is not something done by intelligent people looking for something in this range of performance. MAYBE really high rpm race stuff, but anyone who does it for the street is doing either as a marketing tool to impress the ignorant or is ignorant themselves.
The XFI stuff is perfect if you want to be another sheeple buying mediocre parts that are "supposed" to be the best. Just make sure you are reallly good at making excuses about why it does not perform so you don't have to admit you made a mistake.
Old Dec 1, 2007 | 09:52 AM
Originally Posted by 96capricemgr
Are you kidding?
Come on man, the guy has only been driving for five years. You have to learn some time, none of us were born knowing every thing about performance. Why don't you try to educate insted of slam someone for asking a question!
