Pictures of my stock 100k mile oil pump
~20 at idle, ~30 at 1500, ~40 at 2k, and 50 tops at WOT, all off of the factory guauge. I could have sworn my oil pressure was starting to slowly fall over time and I guess I was right. As far as pulling it, I jacked up the motor until the tranny hit the tunnel, lowered the k-member and took out the back bolts, then the stock pan came right out when I tilted the k-member back. To get in my canton pan I had to lower the shock towers about 1/2", then the pan barley fits in when I tilt the k-member back.
i have my old one from the rebuild - you have peaked my interest....i am going to pull mine apart and see what i find...it had 130k miles on it. I went with the Canton 15-242T and the melling MEL-10552C and the 20-013 pick up.......really nice set up in case anyone is interested. I only had a small amt of clearance issues on the 383 assembly right at the front of the pan on the windage tray flange.
so did you just drop the k member for clearance for the canton pan? i need to see about changing mine just the pump im having psi issues and im hoping it just the pump going bad i have 116k on it just when it gets hot psi drops down to 4
