Think she's got a lil' more in her?
To the wheels I'm only putting down a measly 250 RWHP N/A
hahaha the best part is when you line up with a ls1/ls2 f-body, GTO, or Vette and they just look over and laugh at the line. Then I just flip the switch and I'm gone. Then I'm the one whose pointing and laughing on the return road lol
OWN3D BY MY PROF!
haha pretty much every bolt-on you can think of except roller rockers. The full list is in my sig.
I'm doing it on a MT 275/50R15 Radial...and yanking a tire doing it lol
http://i13.photobucket.com/albums/a2...a/IMG_3268.jpg
Its also a good idea to keep a log of any changes you make in each run...So you have something to go back to, to see what worked and what didn't...
--Alan
Damn, you guys have some amazing LT1's around here! I wish I had know about this site back when I had mine, I think I could have been alot faster, lol.
Great times! Good luck dropping them even further.
Haha, I'll definetly be putting the motor to the test by upping the jets and seeing how much spray it can take, once I get around to building a motor. But I have a feeling the motor cant take much more than a 150 cause it already has 111,000 miles on it lol
And Plus, I wanna keep the motor in once piece for the shootout lol
Hmmmm I'll definetly try setting the rear shocks to 8 and I'll up the tire pressures too. I'm just worried that if I up the tire pressure too much it'll break loose cause of how cold the weather is here in DE/MD.
Quick question on the 28" tires. Will I have to "massage" the fenderwell or trim the bumper for 28" tires cause I know if I were to run a 28" slick or ET Street I would have to or else I would get bad tire rub.
Yeah it looks like a bit of squat...Try the rears on 8 and the fronts on 2 and up the tire pressure to 17-18...Thats what I use and I found that the radials like more air in them...Also try 44 psi in the fronts...By not having the rears tight enough all the energy that should be hitting the tires into the pavement is being pushed up into the wheel well instead of into the track...And the 28"s will help also...
--Alan
--Alan
I run the 275 60 R15 M/T radials on my 15x10 Bogarts with no mods...They fit right in with no problems at all...And the radials don't "grow" so there are no issues when racing them...I see you have a Formula also so I'd think that they'd fit fine for you...As far as tire pressure goes just experiment...I found that lower tire pressures seem to mask suspension problems...I keep adding air until I get a bit of spin, then drop them back .5 lbs at a time till you find what works best for the track conditions...I was right in the middle of finding my spin point when my output shaft in the trans decided to break...but I was hooking best with 18psi...
--Alan
--Alan
