open headers?
Old Dec 4, 2007 | 10:53 PM
94BlackSSClone's Avatar
Default open headers?
would running open headers on my car for a few months be bad on anything? Or is there any way I would lose power and torque because of no backpressure?
Old Dec 4, 2007 | 10:58 PM
GreenBlood's Avatar
It will most likely fry the O2s, and your going to lose some low end torque, not because of backpressure but because of lack of exhaust scavenging.
Old Dec 4, 2007 | 10:59 PM
CRAZZ28's Avatar
you will lose low end. and probably eat up your O2 sensors.
Old Dec 4, 2007 | 11:01 PM
Dave J's Avatar
yes what he said
Old Dec 4, 2007 | 11:26 PM
projekt70chevelle's Avatar
I've run open headers twice, after install and when i took the y pipe off when putting on the cut-out. Both times i drove for a few weeks. O2's were fine, and yeah you loose a little low end but get some more up top. Gives you a headache the first two days but you get used to it lol. Just gotta watch out for the po po...
Old Dec 4, 2007 | 11:41 PM
Gun5's Avatar
ya like he said u cant even idle next to the police if u have a stall or like to slip the clutch alot forget it ur already screwed its not to hard to see open headers either
Old Dec 5, 2007 | 09:45 AM
Red96TA's Avatar
My last car had open headers for like a year and a half (Not mine anymore though)
Old Dec 5, 2007 | 10:50 AM
Bad_tx_Z28's Avatar
seeing as how its winter time...not sure if its cold where you are...but running open headers is okay...but when you shut the car off that cold air creeps up into the headers and can over time crack the valves.
Old Dec 5, 2007 | 11:31 AM
LT1Falcon's Avatar
i dont understand y it would effect the o2's
Old Dec 5, 2007 | 12:43 PM
transamws6_97's Avatar
that doesnt make sense because no matter how long your exhaust is cold air will creep back up to the motor
Old Dec 5, 2007 | 01:51 PM
LT1Falcon's Avatar
i think he means it will creep in there a lot quicker, which wouldnt give the heads time to cool off on their own. not saying hes right but i see what hes saying
Old Dec 5, 2007 | 02:05 PM
The Engineer's Avatar
I run dual-open collectors on my car and also have 18" collector extensions. So, I've got the best of both worlds, low-end torque and no high RPM restriction.
WD
Old Dec 5, 2007 | 02:22 PM
Formula96's Avatar
run 6-8in extensions and you should be fine, and yes, the cold air can crack valves
Old Dec 5, 2007 | 02:32 PM
LT1Falcon's Avatar
bump for this question
Old Dec 5, 2007 | 02:52 PM
Formula96's Avatar
exaust gas cannot push air out fast enough at idle to keep fresh air from getting on the o2s, causing the car to put more fuel than is needed. I don't know why it would burn them up though.
Old Dec 5, 2007 | 02:56 PM
Bad_tx_Z28's Avatar
okay...lets say that you just shut off you car...open yeaders, and it 40 degrees outside...cold air immediatley comes up through the headers and into the cylinders...over time it COULD crack valves...doesnt always happen.
Old Dec 5, 2007 | 03:01 PM
LT1Falcon's Avatar
i agree with you on that. and i dont think it could "burn up" the o2's, theres no theory behind it
Old Dec 5, 2007 | 03:38 PM
I don't think it is an issue of "burning-up" O2s with open-collectors, but that they may not perform "as designed" in an open exhaust system (during closed loop). With the newer design EFI systems there is an O2 in front and one behind each Cat with a closed exhaust system. You open the exhaust system up and everything changes.
Leaded race gas is one thing that will damage the O2s.
WD
Old Dec 5, 2007 | 04:17 PM
Formula96's Avatar
so will coolant and oil....
Old Dec 5, 2007 | 04:29 PM
endobong's Avatar
Ive wondered, Yall ever think about getting a pair of Ecutouts and hooking them upto a rpm activation switch? Maybe set it up at 3200???? I believe the new Z06 has something like this...
