wierd cooling problem
Old Dec 11, 2007 | 09:40 PM
Revelation Z28's Avatar
Default wierd cooling problem
started yesterday. cold start i let it sit to warm up as usual. then i saw a few drips coming from near the oil cooler lines to the radiator where they connect to the rad. i thought it was leftover rain caught in the front frame. well i guess not cause today whenever i sit and idle itll heat up to 3/4 from 180 within 1-2 minutes. driving on the road and freeway itll stay normal 180-200*. coolant level is fine in the radiator and overflow. no oil mixed in anything. but i smell coolant as its sitting right now in the engine bay.
Old Dec 12, 2007 | 12:52 AM
TXFORMULA's Avatar
well im assuming you have a low temp thermostat and lower temp or manual fans with all your other mods.if not it wouldnt hurt. my car did what you are describing bc of the poor factory tune. to the point it boiled out of the overflow. that would probably cause you to smell coolant. if you ARE running lower fans and thermostat than it sounds like you could have an air pocket in the system causing a hot spot. aren't the oil cooler lines on the passenger side? if i remember correctly the coolant temp sensor is right above it-could be leaking from there. the factory o-ring is crappy.
Old Dec 12, 2007 | 12:55 AM
the oil cooler lines are on the same side as the filter. drivers side.
its not coming from the overflow. its coming from the drivers side of the radiator behind the fan plastic. the guard or whatever it is that bolts to the radiator. i checked right now and you can see its dry trail. i looked at the cap side of the rad. and its crusty. 8 month old cap is bad i bet. its a very small leak. maybe 3 drips per minute. only does it on cold starts and when its cold.
im running stock tune and stock fans/stat.
Old Dec 12, 2007 | 01:03 AM
TXFORMULA's Avatar
the low temp stat would drop your temps quite a bit but you either have to get a tune or a hypertech to adjust fan settings unless you just want to run a manual fan switch.i prefer to have it set lower in the tune so i dont have to mess with a switch.your stock fans are not coming on until 225*! now if you think you are seeing some fluid from where you are describing, that is part of the radiator. mine had a hairline crack that was only leaking when it was hot. my temps starting going up a bit more and the rad had to be replaced.
Old Dec 12, 2007 | 01:16 AM
my radiator is like 2 years old though. this is wierd. it just started happening yesterday morning on the cold start. i dont think it would crack from sitting in the garage or starting up. it does look like the coolant is coming from the cap though.
im gonna dynotune the car sooner or later so im gonna have the fan temp lowered and everything.
Old Dec 12, 2007 | 05:20 PM
TXFORMULA's Avatar
maybe the leak is from the cap then. if you want to take a closer look theres not much to getting the fans out of the way. disconnect negative battery terminal,disconnect two fan plugs that run into the fans right near the center of each fan,then remove the radiator mount,then it shouldnt be too hard to unhook the fans from the rad and take a better look. if you try it and decide they need to be moved all the way the fans come out very easy dropped out the bottom. on the thermostat thing, i run a 160* and my temp sits around 180* at its hottest. from what you said id try a different rad cap,then try bleeding it to rule out an air pocket first.
Old Dec 12, 2007 | 05:32 PM
Bad_tx_Z28's Avatar
im having similar problems...i just replaced my waterpump about a week ago...filled it all the way up with coolant...and then a few days later i have to filil it back up a little to the top of the radiator...i havn't noticed any leaks or smells...any ideas?
Dont mean to thread hijack BTW
Old Dec 12, 2007 | 05:55 PM
TXFORMULA's Avatar
its probably just your system filling all the way back up. check it here and there before taking off until it seems to have stopped,then if you get a low coolant light here and there and it seems full,then when it comes on try turning off the motor/ignition,then turn it back on and it should go away. if it doesnt then it could be a few other little things...
Old Dec 12, 2007 | 06:15 PM
chavez885's Avatar
probably have air in the system, try to get that out..
for you rev.....sounds like possible waterpump to me...does it like while its running or after you kill the car?
**nevermind rev,didn't realize the leak was from the front...have you tried maybe diff coolant cap? sometimes the simple stuff ya know..
Old Dec 12, 2007 | 06:16 PM
no no the problem is its a very small leak on cold start. barely a leak at all. but its enough to make it heat up sitting in traffic. driving will make it cool back to 180-200.
Old Dec 12, 2007 | 06:21 PM
Bad_tx_Z28's Avatar
what is the best way to bleed the system...and BTW i have noticed...that when i take my radiator cap off i hear a big gulping sound...related?
Old Dec 12, 2007 | 06:23 PM
chavez885's Avatar
Yes you definately did not fill the system up right lol...i'll pm you some links so we don't kill rev's thread.
Old Dec 12, 2007 | 06:40 PM
chavez885's Avatar
Also you said the coolant looks like its coming from the cap,change that first,that could cause air to get into the system and make you overheat. If that isn't the problem, maybe be a bigger issue.
That's really wierd that the car would overheat from just a leak,something in the cooling system is not functioning, i really wanna say waterpump or thermostat IF the cap doesn't do anything for ya.
Old Dec 12, 2007 | 08:57 PM
wp is circulating. stat is opening and closing. as you are
Old Dec 12, 2007 | 10:14 PM
TXFORMULA's Avatar
isnt 3/4 of the way on the temp gauge about 220 ?its going to heat up to that when you are just sitting there with the stock stat and tune.then when you take off and some cool air hits it again it will drop back down until you are sitting still again just like you are describing.
Old Dec 12, 2007 | 11:13 PM
yea but since its been around 50* here lately its been going up to 1/2 max when sitting at all.
