View Poll Results: Jet Hot vs. Pacesetter
Jet-Hot
6
50.00%
Pacesetter
6
50.00%
Voters: 12. You may not vote on this poll
jet-hot vs. pace setter
Old Dec 20, 2007 | 08:58 AM
Schweet97Z's Avatar
the insides of my pacesetters came coated. as far down as i could see through the primaries with a flash light.
Old Dec 20, 2007 | 10:40 AM
matt94z's Avatar
I have Jet Hots and they are very nice headers. I haven't had any problems at all in 3+ years.
Old Dec 20, 2007 | 12:56 PM
Formula96's Avatar
jet hot here, no problems 4+ years.
Old Dec 20, 2007 | 01:01 PM
LT1MAN's Avatar
my first pacesetters were warped on the flanges and leaked terribly, not to mention they send you cardboard gaskets and expect them to hold up. and second the customer service was nothing to brag about either, took them 3 times to get me headers that worked. and on top of that i had to beat the primary to make room for the damn steering knuckle. i can't comment as far as the install bc my jet hots went in bolted to the motor on the cradle. i would highly recommend anything besides pacesetter.
Old Dec 20, 2007 | 01:10 PM
slick1851's Avatar
Pace Setters are the ****
Old Dec 20, 2007 | 01:32 PM
97LT1's Avatar
Originally Posted by burnzilla
The Jet-Hots are a more quality header.
Jet Hot also coats both the inside and outside of the header, unlike Pacesetter which only coats the outside.
If you want, you can buy black painted Pacesetter LT's right from Jet Hot and have them coat them with thier sterling coating, then the Pacesetter Y-pipe would work.
my pacesetters are coated on the inside also, not to mention the flanges come thicker than jet hot's which is a plus to prevent warping. My pacesetters were very straight on the flanges for those wondering. I am sure both of these sets are great headers for the $. I will splurge on stainless set later.
Old Dec 20, 2007 | 08:32 PM
BOLO's Avatar
JetHot headers are a Hooker design,JetHot made the flange thicker and ofcourse added their coating. I think they also use the same part #2231 as Hookers.
I've had them now for almost three years and no issues. The installation was a breeze for me, may be ten to fifteen minutes each side.I did mine when I was doing heads and cam.
Old Dec 20, 2007 | 08:51 PM
chavez885's Avatar
my pacesetters went in like cake,fit was good,flanges were good. I'm happy with them. I don't see how kooks are worth 500 dollars more
Old Dec 20, 2007 | 09:40 PM
fireman's Avatar
I have had both, ceramic coated.
Pacesetters are nice, they have revised the design over the last few years. I have the latest design on my car right now. Super easy install, thick flanges, no leaks, easy plug access, nice finish. And for those of you who don't know, Pacesetter uses Jet hot coating on their headers, they just have to call it something different. I could not be happier with my Pacesetters.
Jet Hots are garbage. Unbelievably hard install, they fit like ****, and the plug access is not as good as the Pacesetters. Yeah, the one primary comes apart and also leaks where that joint is. I had the engine out of the car, on the Kmember, and it still was a major PITA to remove them from the motor. It easier to R/R the Pacesetters with the motor in th car than it is to R/R the Jet Hots with the motor out of the car.
Old Dec 21, 2007 | 02:11 AM
96LT1355Z28's Avatar
Originally Posted by 96LT1355Z28
My Pacesetters installed great, with a good fit, and I've had no leaks. Great for the money IMO, but like I said others will disagree.
Sorry, I couldn't resist!
Old Dec 21, 2007 | 03:25 AM
matt94z's Avatar
How was it hard to remove them when you had the motor out of the car? I can change plugs in about 30 minutes. All of the plugs go in from the top except #8 and drop down the alternator for it. And I have big hands and arms...
Old Dec 21, 2007 | 06:48 AM
  #32
fbodyfreek's Avatar
thanks for all the input guys. i added a poll to see the results better. so go ahead and vote.
Old Dec 21, 2007 | 09:43 AM
  #33
blk97z28's Avatar
I have pacesetters and here are the pics.
Old Dec 21, 2007 | 09:44 AM
  #34
blk97z28's Avatar
That is why I chose them b/c they kick ***!!!! Only cost me 385!!! total cost was 385 for headers, adn 120 for y-pipe!
Old Dec 21, 2007 | 11:46 AM
  #35
Torkman15's Avatar
10 Second Moderator
The #1 primary on those Pacesetters would have given me more room for my ABS delete and linelock. My Jethots are rusting between the #3 and #5 primary tubes. I hate rust! I have a set of Pacesetters for LS1 waiting for the swap so maybe if I have time this winter....
Old Dec 21, 2007 | 07:24 PM
  #36
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Check out EDELBROCKS, also.
Old Dec 22, 2007 | 09:04 AM
  #37
Z-RATED94's Avatar
Lets please get it right. Pacesetters ARE coated on the inside. DO have thick flanges. ARE a great bang for the buck. HAVE very good access to the plugs.
DO NOT have a slip tube that can leak.
And what does a different model vehicle and Pacesetters have to do with an F-body?
