misfire, knock, surging rpms
Old Dec 19, 2007 | 09:50 PM
94BlackSSClone's Avatar
Default misfire, knock, surging rpms
Well, my 94z is having some problems....I noticed the other day that the rpms were surging up and down from about 1500 to 1800. It would go back and forth but was only when I let completely off the gas. For about a month now, I have thought that it has been having a little rough idle. The rpm's dont jump around much(but will a hair) and there is a vibration that doesnt feel like it should be there.
Tonight on the way home from work, if I punched the gas or tried to accelerate hard, the engine would knock and almost die. It is fine if you are just cruising along and slowly raise the rpms and was fine just cruising. Any advice or what this could be?
Newly built tranny
93 octane gas
automatic
replaced spark plugs about 3,000 miles ago(but not sure if the guy did all 8 or not....he should have seeing as how I gave him 8 plugs.
but:I didn't replace spark plug wires
Old Dec 20, 2007 | 08:37 AM
96LT1355Z28's Avatar
It could be any number of things at this point. Did the problem exist before you had the plugs put in? Is it setting any codes? Make sure all you're sensors are pluged in and the plug wires are on the correct plugs. You might also check you're fuel pressure.
Good Luck!
Old Dec 20, 2007 | 12:12 PM
I never noticed the problem before the plugs were changed...but the roughness could be because I put poly engine and trans mounts...but the stumbling under hard acceleration wasnt there until last night....still there this morning!
Old Dec 20, 2007 | 12:52 PM
Formula96's Avatar
maybe your idle air control valve, It would cause a messed up idle and if it was stuck open too far under WOT, maybe to much air, causing lean conditions, knock...
Old Dec 20, 2007 | 02:48 PM
thats a very good idea....i'll be sure to check that! How would you check it?
Old Dec 20, 2007 | 02:59 PM
Formula96's Avatar
well, hmm, i worked for a dealership, so we could check them with a scan tool to see what it was trying to do and what it was accually doing.
let me think for a minute and get back to you...
Old Dec 20, 2007 | 03:21 PM
Formula96's Avatar
cant come up with anything, maybe unplug it and see what your idle does...
Old Dec 20, 2007 | 03:45 PM
Do you have a Haynes or Chiltons repair manual?
Old Dec 20, 2007 | 03:57 PM
According to a Haynes maunal once you unplug the IAC the computer will have to relearn the Engine idle speed, this may take a few minutes. The maunal says how to check the ohms on the IAC and TPS.
On the missing, it's possibly a bad plug(s), if they were rough with them on the install a few heat cycles may have cracked a plug(s). When I rebuilt my motor I put in new plugs and my wires were only about 6 months old. I had two dead cylinders! I replaced the plugs and wires and it fixed the problem. However mine didn't miss or cutout it just lacked bottom end power. It did have an unusual vibration at around 3500 rpm.
How's fuel psi, filter?
I'm just guessing, Good Luck!
Old Dec 20, 2007 | 06:37 PM
Shawn MacAnanny's Avatar
http://shbox.com/1/iac2.jpg
Old Dec 20, 2007 | 09:46 PM
thanks guys, I will try this tommorow!
