pacesetter banging
Old Dec 21, 2007 | 07:25 PM
transambandit's Avatar
Default pacesetter banging
okay i know that pacesetters have problems with banging under the drivers side and i saw a fix for it somewhere but i cant find it now, anyone know where i can buy the clamp that will stop the banging.
Thanks
Old Dec 21, 2007 | 07:26 PM
Schweet97Z's Avatar
put in poly motor mounts.
Old Dec 21, 2007 | 07:30 PM
Schweet97Z's Avatar
....or this
http://www.thunderracing.com/catalog...&sid=528#P3780
Old Dec 21, 2007 | 07:34 PM
Rocky70304's Avatar
wow, that is a trick invention.
Old Dec 21, 2007 | 08:01 PM
Originally Posted by Schweet97Z
Tight, this is what ive been looking for, cool thanks
Old Dec 25, 2007 | 04:48 AM
Boodyrider's Avatar
Or you could just weld a valve spring to the top of the pipe between the pipe and the body. Costs all of $0.50 worth of welding rod and a junk spring.
But hey, that $40 solution looks cool.
Old Dec 25, 2007 | 09:55 PM
fbodyfreek's Avatar
so is it necessarily guaranteed to knock or does it just happen with some applications? like, should that piece be ordered with the headers and y pipe ya think?
Old Dec 25, 2007 | 10:03 PM
from what ive seen and with mine its about 90% that it knocks, though mine usually only knocks when i step on it.
Old Dec 25, 2007 | 10:15 PM
Z-RATED94's Avatar
Thank you. I pretty much have the banging fixed, but I like that way much better.
Old Dec 25, 2007 | 10:16 PM
Luna's Avatar
the bump stop thing from thunder doesnt work... well it didnt for me, it may for some.
I put poly's in and still had banging! I had VERY little clearance between the headers and the floorboard.
Some thick heater hose and a hose clamp and all is quiet
