Weld wheel sizes
Old Dec 22, 2007 | 08:54 PM
C5042081's Avatar
Default Weld wheel sizes
Looking to buy a set of weld draglites or prostar front and rear
What size will fit a stock 10bolt?
offset??
Any mods needed to fit 15"?
TY in advance
Old Dec 22, 2007 | 09:11 PM
The Engineer's Avatar
The rears for 4th Gen F-Bodys are 10" rim width with a 7" or 7.5" back-spacing for most slicks (28" x10.5).
The back-spacing options are limited on the 3 1/2" front rims and you may need to use a small spacer for the spokes to clear the calipers.
Double-check the clearance to make sure the wheels aren't rubbing the calipers. Also, you may need to do some minor ginding on the calipers for clearance.
WD
Old Dec 22, 2007 | 09:17 PM
black383's Avatar
what is stock bolt pattern?
Old Dec 23, 2007 | 06:59 AM
5 on 4 3/4" which is standard for "most" GM cars (all F-Bodys).
WD
Old Dec 23, 2007 | 11:17 PM
skinnies's Avatar
15x10 7.5bs 325/50/15 mt dr's
Old Dec 24, 2007 | 02:21 AM
the_merv's Avatar
Veteran: Air Force
^^That car looks sharp..I need them in the back..
Old Dec 24, 2007 | 07:48 AM
Schweet97Z's Avatar
my welds are on the way as we speak. now its just time for some street wheels
Old Dec 24, 2007 | 09:56 AM
Smokinlt1's Avatar
I'm running 275/50/15 on 15x8s on the rears[/IMG]
Old Dec 24, 2007 | 01:12 PM
C5042081's Avatar
whats the bs your running on the rear?
Old Dec 24, 2007 | 02:34 PM
Schweet97Z's Avatar
it is recommended to run a 5.5" backspacing on an 8" wheel. im going 15x10 on the rears and am using a 7.5" backspacing.
Old Dec 24, 2007 | 02:45 PM
The LT1 That Could's Avatar
this might be helpful to you..
http://www.freewebs.com/casper9t9/dragwheelinfo.htm
Old Dec 25, 2007 | 08:50 AM
Smokinlt1's Avatar
sorry about that I meant to say 5.5bs
Old Dec 25, 2007 | 06:30 PM
C5042081's Avatar
Originally Posted by The LT1 That Could
thanks, great write up
Old Dec 25, 2007 | 07:32 PM
CamaroRacing12's Avatar
with this post being up.... anyone got some 15x3.5 w/1.75 bs and/or 15x8 w/5.5 bs prostars? im looking to spend around $800
Old Dec 26, 2007 | 01:10 AM
Schweet97Z's Avatar
you can get a brand new set of wheels for around 630 bucks. you will go over ur budget alittle w/ tires
Old Dec 26, 2007 | 02:12 AM
Z-RATED94's Avatar
Add a little more $ and get a set of Bogarts. 4" fronts and 9 3/4" rears. Less weight, no grinding, no spacers. Both front and back tuck in nicely and have a better look.
Old Dec 26, 2007 | 04:25 AM
Schweet97Z's Avatar
umm Bogarts are def. alot more money than the Welds.....for as much as I take the car to the track, id rather save the HUNDREDS of dollars and grind the calipers and deal with spacers. JMO
Old Dec 26, 2007 | 11:10 PM
i love the look of the prostars....
but what are those u have in ur sig pic? they look sweet!!!
Old Dec 28, 2007 | 05:47 AM
Razor_Blade's Avatar
Keep a look out in the For Sale section. Some good deals pop up on ocasion, but they won't last long so you have to be ready to move.
I bought my Draglites in like new condition with lug nuts, center caps, spacers, and new MT drag radials for $700.
