lt4 hot cam vs. CC503
#43
Based on the results I've seen, I'd say it out does the Hotcam throughout the powerband. You probably won't find a fair back-to-back comparison of the 2.
Mike
#45
hmm im sort of leaning towards the cc503, summit says it makes power from 1800-5800, which is a little different from what i've read on this site tho ?? wth..?
link :
http://store.summitracing.com/partde...8&autoview=sku
link :
#48
the 305 has a little more lift on the intake but less duration. the 306 is pretty big for stock unported heads. im not saying it wont work but why run a bigger cam when you dont have to. to get the full benefit from a 306 you will have to spin the motor higher than i'm sure you want to.
#49
you should read this over carefully and you will understand why: https://ls1tech.com/forums/lt1-lt4-modifications/836200-stock-head-cam-cam-swap-guide.html
#50
This d@mn cam decision has been officially over-thought and discussed too much. Stock Eliminator racers don't spend this much timing choosing a cam! At this point, I don't really care which one you get - just make a decision.
Is there any way to un-subscribe?
Mike
Mike
#53
[QUOTE=engineermike;8385994]This d@mn cam decision has been officially over-thought and discussed too much. Stock Eliminator racers don't spend this much timing choosing a cam! At this point, I don't really care which one you get - just make a decision.
..... what the F ?
well mr. superstar engine builder "engineermike" next time I have questions I will be sure to refrain from going into detail as to not "offend" your superiority..
pffftt...
..... what the F ?
pffftt...
#54
There probably isn't 10 hp difference between all those cams, so my point is that you're laboring over something that isn't going to make that big a difference.
