Cut out around foglights for FMIC (pic inside, need opinions)
#43
Yeah but look where the opening is in conjunction with the point of the nose(2nd pic). It is too thin right there. It looks ok from the front, but once you get a look from the side it will look weird i bet. I say get a junk nose from a wrecked TA and experiment.
#47
I think that second photoshop of the original photo looks pretty good. If you don't want to cut it you could make a shroud for it. Dual inlets that go all the way to the intercooler. You could make it out of sheet metal and it would be decently stealthy.
Shants. Shorts the length of pants.
#48
+1 Get a cheap nose and hack it up. You can have the biggest IC in the world but it won't be as effective without any airflow.
#49
I think I'm going to cut it out and if I don't like the look of it I will do exactly what you said and then paint the grill the same color as the car
