LT1 Project
Old Apr 16, 2008 | 04:11 PM
  #161
MARKSZ71's Avatar
congrats larry enjoy
Old May 4, 2008 | 07:38 PM
  #162
jokesover's Avatar
larry what did the car ever run
Old May 4, 2008 | 08:10 PM
  #163
LS1 SPEED's Avatar
crawl'n
weather and track where not the best in KS for the shootout
best ET 10.7
best MPH 125
I said I would be more then happy with a .50 and I know it will do that with some tweaking on the suspension and Byron's bite.
figure I put an easy 150#'s in the car now with the cage, 12 bolt, drag sway bar and wheels/radial tires
car was not running 100% either and we found the MAF to be bad and I moved the IAT since I feel it was to close to the nozzle and causing it to run really rich at times on the jug
I plan to go to Byron this Saturday the 10th if you want to head out.
Old May 5, 2008 | 08:41 AM
  #164
Colin91Z's Avatar
A little off topic, but it was good to meet you guys at the Super 8, and this car is friggin beautiful in person
Old May 5, 2008 | 06:20 PM
  #165
jokesover's Avatar
larry how big of a hit.mild steel or moly cage
Old May 5, 2008 | 09:45 PM
  #166
LS1 SPEED's Avatar
Colin...same to you man.
Jay... 150, but it was running pretty rich.
10.8-11.2 area
Wolfe mild steel 6 pt.. 85#'s alone
not looking good for me at the moment to get the new gear in , MAF and tuned by Sat
BTW : you are always welcome to give me a ring and shoot the **** for a few minutes
Old May 11, 2008 | 03:07 PM
  #167
LS1 SPEED's Avatar
Default made it to the track
3180 #'s + me ! 195 = 3375 race weight
The 275/60 seem to be hit or miss and I can not get a good feel for them.
H/C and stock 90K + shortblock + 150 shot ( did not run on HP )
best 60ft 1.41
best ET 10.56
best MPH 126
101.89 mph in the 1/8 which makes me believe my converter maybe a bit inefficient on the big end
I am very happy with the car and the fact I drove it over an hour each way with no issues. I am sure it will go 40's with some little tweaking.
cruising @ 3500 RPM can make your ears ring after an hr !
Old May 11, 2008 | 04:19 PM
  #168
TwoFast4Lv's Avatar
Do not feel bad Larry mine is about 50Lbs heavy as am I
Even wth CM a NHRA Cage is heavy!
Old May 11, 2008 | 05:36 PM
  #169
Z-RATED94's Avatar
best 60ft 1.41
best ET 10.56
best MPH 126
Try being a printer for 35 years, that make your ears ring ALL the time. Nice short time, and I'm sure you will figure out what the car needs/wants.
Old May 11, 2008 | 06:53 PM
  #170
BOLO's Avatar
Congrats Larry, nice times. Too bad I missed it. You maybe right on the converter. Well, you know more about this things, I'm sure you'll figure out something. Talk to you later.
Old May 11, 2008 | 07:41 PM
  #171
LS1 SPEED's Avatar
thanks guys
I'm am happy even if it goes no faster. I really want to put a 4L60E back in the car, so most likely I will not play with the stall.
I wanted a 10.5 driver and it did it the first time out and there is still some left in the car with further testing.
Old May 11, 2008 | 11:09 PM
  #172
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Those are some good times for your first time out!
Old May 14, 2008 | 04:35 PM
  #173
DTB_LS1's Avatar
Wow Larry, I don't know which of your cars is cleaner the Notch or the Z. Great looking car, I'm looking forward to seeing it at Byron this Summer.
Old May 14, 2008 | 04:42 PM
  #174
LS1 SPEED's Avatar
The Notch hands down !
Old Jul 3, 2008 | 08:44 PM
  #175
LS1 SPEED's Avatar
lil update
a few weeks ago I ended up have Chuck & Vince @ FLT build me a Level 4 4L60E, ordered a Vig 3600+ and also got all the custom power steering stuff together
The car is now on the road with the above and really love the fact that it can be driven anywhere now.
Old Jul 3, 2008 | 10:55 PM
  #176
96autoformula's Avatar
I have a 4L60E and 3600 Vig from your old trans guy and i swear by that thing. Cruisin at 75 at 2750 is a beautiful thing with gas prices. And it holds up to 400 hp eliminating the other issues which is a definite plus.
Old Jul 3, 2008 | 11:36 PM
  #177
BOLO's Avatar
Hey Larry, just curious, what did you do with the TH350?
And yes, going with the 4L60E is beautiful thing.
Old Jul 4, 2008 | 06:32 AM
  #178
LS1 SPEED's Avatar
yep..I do not miss 60mph @ 3500 rpm ! so nice to fly down the HWY @ 70-80 now under 3000 rpm
TH350 went to a friend to put in his girlfriends 97 T/A
Old Jul 7, 2008 | 06:46 PM
  #179
BADHAWK51's Avatar
Larry I'm sure I will be going back to the electronic junk someday myself. I'm getting tired of the Import guys blowing past me on the highway.
Old Jul 7, 2008 | 09:03 PM
  #180
LS1 SPEED's Avatar
tell your boy to keep his car in the garage then
see you at the show tomorrow?
