I diddnt know headers F***** up Lt1's this much
I'm thinking plug wires. My car ran nice with no load on it and when it had any kind of load it would run like total garbage. Check for missing header bolts and header leaks but more importantly a wire that is burnt and is now arching. I burnt a couple wires and they were arching to the one of the header pipes. Problem solved.
-brian
-brian
ok I will take a look into the MAF also. and see what comes up. Those are pretty expensive though? dammit
also I dont have coated headers, and my brother and I are good at soldering so we will probably go that route.
Problem is I am leaving for college and I put my car into storage so if I dont get to it this weekend then I will look into it around may. This will give me time to order the correct delco parts and such.
-brian
-brian
If it were plug wires it would run bad all the time.
The o2 sensors are not used until the car is warmed up.
Are your headers long tube? Pacesetter dosn't include o2 extentions. Instead they give you a roll of wire to extend the o2's which is a horrible idea. When I installed mine i had the same problem after a few months and that was it. If this is the case buy new o2's from a gm dealer (part store o2's are junk and will cause problems down the road) and get o2 extentions which I bough through summit racing for like $20 each. This is a common problem and so far this is the best solution. I didn't read the whole thread so excuse me if I missed something but this is exactly what I went through. Good luck and I hope this helps you.
I just read the rest of the thread and it sounds like I was right. Casper electronics makes the o2 extentions I have and the 12" are long enough. Buy 2 of them and new ac delco o2's from a dealership. I promise you this is your problem. I've fixed this problem on several cars since it happened to me and it did the trick every single time.
I am thinking it is the plugs/plug wires and/or the o2 extensions. I had the same symptoms that you are having, and I got to tearing **** apart, and realized that it was frayed/fried wires and fouled plugs. +32432 on the AC Delco platinum. They are the ****, and are not that expensive if I remember right. For a street car, they will work great. Might as well go for all MSD wiring and AC Delco plugs.
I had several issues with my 93 when I put headers on it.....1. I had to go with an LT4 knock module because the computer was pulling 8 degrees of timing out at WOT 2. I put heat wrap around most of my plug wires because several melted and others got real spongy from the heat and did not work correctly 3. I bought Bosch 02s which never worked right, I ended up buying AC Delco and my problems went away.
Also, don't use Bosch plug they suck too.....
just installed my pacesetter long tubes this weekend and she cranked right up. Ran her around the block with open headers only with no pipes yet, man was i disappointed. Sure it was loud as hell but had no throttle response at all. Felt like i lost power. I know it was probably the lack of back pressure. Can someone verify this??? Also i have the drivers side O2 sensor totaly removed from the harness for splicing right now the car wont even start. does the computer recognize this as a error in the system and stop the car from turning starting up????HELP
