predicting numbers...
I'm almost done putting together the motor for my Firebird. I'm swapping a LT1 into my 95 3.4 car. It's been a long road and I'm ready to be driving it again.
The end setup will be:
-355ci LT1 (bought the block used with aftermarket crank, SCAT rods and SpeedPro pistons)
-Stock 93' Firehawk heads milled to 11.1:1 CR & 3 angle valve job, all new valves and Impala headgasket
-Comp 918 springs
-Scorpion 1.6RR
-CC503 cam
-double roller timing chain
-CSR electric waterpump
-hand ported LT1 intake
-58mm Holley throttle body
-stock injectors
-JetHot LTs and ORY
What should I expect or what numbers could I be seeing hp/tq wise? I have a number I'd like to see but I'm curious what other people think.
I was lookin a guess for more on power numbers hp/tq...
As far as driving...I could drive the **** out of my V6, turns are one thing though, I've been more into twisties and what not more than straight line. Obviously because in the past I've just gotten embarrassed...
...so I guess we'll see...haha
If you can get it to hook, low to mid 12's should be obtainable. Good luck.
if so, i can't freaking wait to get mine running it sounds great!
