PCM for less tune
Old Jan 22, 2008 | 06:46 AM
  #41
Smokinlt1's Avatar
When I had my Hotcam, Byran did the tune and it never was right( too rich). Now with a stock motor I have Ion's tune and it is dead-on. I had purchased a lifetime email tune from Byran only to find out it's only good for 3yrs and needed to pay for another tune so
I went with Ion this time.
Old Jan 22, 2008 | 08:23 AM
  #42
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
So, is pricing the only signficant difference between the two?
Old Jan 22, 2008 | 01:02 PM
  #43
tspence45's Avatar
Yeah, MadZ28 is cheaper, but, from a lot of responses I'm hearing, they also have the better results.
Old Jan 22, 2008 | 01:49 PM
  #44
roadhog_113's Avatar
since when is a lifetime 3 years? THATS DUMB!!
Old Jan 22, 2008 | 04:01 PM
  #45
siniSSter's Avatar
I currently have PCMForLess tuning at the moment. I'm not very happy with the tune I currently have. The car is running rich, surges at idle, and surges even more as soon as the car hits overdrive. I haven't sent it back to get fixed, but I think I'll look somewhere else for a better tune.
Old Jan 22, 2008 | 05:02 PM
  #46
tspence45's Avatar
Man, it seems like a lot of people have some troubles with PCM4Less. I guess it was good that I asked this question then. Otherwise, I probably just would've went ahead and got a PCM4Less tune. Now, I'm pretty much sure I'm going to go with MadZ28.
Old Jan 22, 2008 | 05:19 PM
  #47
Rocky70304's Avatar
I've used pcmforless.com twice now, and had excellent luck both times, am using it on my current project with no complaints what so ever.
Old Jan 22, 2008 | 05:44 PM
  #48
infinitebird's Avatar
Originally Posted by tspence45
Also, if I have them tune a PCM and do the exchange, I'll have to have an LT4 Knock Module to put into it, if I get it tuned for an LT4 Knock Module, right? Or do I even need one since, in the description, it says that they tune to desensitize knock?
You don't really need it if you ask for that in the tune. And there is nothing to tune for an lt4 knock module, so you can still add one if you want.
Old Jan 22, 2008 | 07:11 PM
  #49
SickboyT/A's Avatar
so what im reading is pcmforless is hit or miss...very interesting
Old Jan 22, 2008 | 07:33 PM
  #50
Schweet97Z's Avatar
everyone claiming their tune is rich....how many of you have a wideband air/fuel gauge? (a narrow band doesnt cut it!)....i bet maybe 1 or 2 of you at most have the gauge to be sure that your car is rich....the rest of you are just making assumptions...... i swore my car was rich, before i had bryan dyno tune the car. the air/fuel ratio was dead on first pull w/ out him making any adjustments. i got the same mail order tune every other le2/gm-847 guy out there got from bryan. and its better to tune a car alittle rich than lean....no mail order is exact, but mine was damn near close.
Old Jan 22, 2008 | 07:40 PM
  #51
tspence45's Avatar
Ah, I see. Well, I was thinking about buying one to run on my stock PCM for now, until I end up ordering a tuned one from MadZ28. But, maybe I'll just save the money and put it towards the tuned PCM, so I can get it quicker. Then, I just won't worry about getting an LT4 KM.
Old Jan 22, 2008 | 07:42 PM
  #52
hehe, I agree. I would be willing to bet not many of them.
Old Jan 22, 2008 | 07:45 PM
  #53
mean94lt1's Avatar
had my car done by bryan and he did a great job he will be doing it again this spring good huy to deal with and is willing to help with questions you have
  #54
LethalZ's Avatar
i also got a madz tune with Ion and i am more than happy with it.....
Old Jan 22, 2008 | 07:55 PM
  #55
Schweet97Z's Avatar
Old Jan 23, 2008 | 08:54 AM
  #56
PCMFORLESS's Avatar
Actually what happens most times is mechanical/sensor issues with a car. I have a HUGE library of files for the LT1 and LS1 cars and they cars are very repeatable time after time. Yes, you do get times when one car with the exact same setup is a bit different than the next, but not by much.
What seems to happen more often than not is simple things like the throttle blades are not opened enough (causing idle surge and a seeming rich condition as the car is basically choking as the IAC motor cannot open enough to get the necessary idle air into the engine), or guys do long tube installs and get the O2 wires melted to the headers, or make their own O2 extentions and don't soder the wires and crip the connections instead, or what has been happening a lot is the coating on headers bake onto the O2's and ruin them by making them read lazy and fool the PCM into thinking it is lean when it is not.
Other issues I have seen have been things like timing chains a tooth off on cam installs, vacuum leaks, dirty MAF's (this is a big one too and causes many cars to run lean, a simple MAF removal and spraying it down with cleaner does a world of good and should be normal maintainence), clogged cat converters, misadjusted fuel pressure regulators, bad/misized injectors, ill placed MAF sensors and blowoffs on supercharged cars, and overtightened roller rockers.
With so many mechanical issues possible, even the perfect tune cannot overcome simple mechanical mistakes. The problem is, you try to help someone diagnose these problems and you get the typical "there is no way I did something wrong when I put it together" isntead of the "yes, let me check that"
I've done so many of these cars (thousands) that I have seen it all. And most times the problems are fairly easily diagnosed and exhibit the same symptoms every time and each mechanical issues seems to have it's own specific symptoms. So many people though think that it has to be something in the computer as that is the "easy" fix. Thing is, the GM closed loop system is more in control of part throttle than myself or any other tuner. It uses the O2 feedbacks and MAF readings to adjust it's fueling. Yes, I set up the injector constants, and VE tables to help get the GM closed loop system a good start so it has to adjust little if any, but the bottom line at the end of the day is even if I am dead on, if the sensors feed garbage to the PCM the PCM will adjust with closed loop and override anything I do. Also, to all those who seem to think that a certain smell means you are rich and have never put the car on a wideband.... A car with a big cam like a 306 Comp cam and no cat converters.... WILL STINK, but is it running rich, no. Slip her onto the wideband and you will see 14.7 to one all day long.
Have I ever had a program that was not right, sure, with as many as we do, ALL of the big name tuners have made a mistake now and then, but 98% of the time, sensors, mechanical issues, or simple adjustment to things like throttle bodies and TPS sensors are all it takes to get everything dialed in. Take any two hotcam cars with the same modifications and put the same program in them and they will be within 3 to 4 % of each other every time, but have the one car with the rockers overtightened by a turn and it will change drastically.
Old Jan 23, 2008 | 09:06 AM
  #57
PCMFORLESS's Avatar
Would a price match policy like Walmart and the other retailers be of interest to you guys? I could do something like this. If someone wanted to order and quoted a competitor price we could do a price match. We believe we have a superior product, more years of experience, and better phone/tech support that makes it worth a few more $$$, but price matching could be doable.
Old Jan 23, 2008 | 09:07 AM
  #58
blackz6sp's Avatar
Well said!
Old Jan 23, 2008 | 10:33 AM
  #59
Smokinlt1's Avatar
What about a lifetime free updates being lifetime and not 3yrs? Was not a happy camper when you told me this!
Old Jan 23, 2008 | 10:56 AM
  #60
u wanna know if your car is running rich? CHECK YOUR PLUGS, it should be done regularly anyway.
