miss / vibration help please
What if the injectors are dirty and stuck open a bit. Under low RPM, it's getting just a bit too much gas and stumbling, but under higher RPM that fuel is being used. I'd go have the injectors pressure cleaned with a system from a shop. They can hook up a can with cleaner in it, and then feed it into your shrader valve and force that in via compressed air. My buddy has the system and it works really nice. You can run any cleaner in there you like too, be it Sea Foam, or Chevron stuff, whatever. A friend had it done at a dealer and it ran $150 (pontiac) but I'm sure a local shop would charge less. I think $75 is a fair deal for that. If you live in Minnesota, but buddy could do it for you
Also, other than the IAC (which I like that theory), maybe possible TPS issue?
I do not think its a fuel problem. I have access to a fuel injection cleaner system that you pressurize and run the car off of fuel and top engine cleaner. The coil should be sparking constant and its not. Im almost positive mine is an ignition/sensor/pcm problem.
I was messing with the car last nite and i found that my vaccum line from the opti to the intake tube was messed up and disconnected. I reconnected it to a vaccum source and the car runs much better. I thought that was just a vaccum line to keep moisture out? Does it control timing or anythign? I just dropped the car of at GM to get a scan and see if they can find anythign becuase it runs better but its still low on power. Ill let you know.
