How can I get into the 11's?
Old 02-11-2008 | 06:53 PM
mack's Avatar
Default How can I get into the 11's?
My best run is a 12.98, 1.96 60 ft at 106 mph on MT DR. 3300 lbs.
Current Set-up:
I have converted the car to functional ram air, have all the suspension mods w a 502 cc, 1.6 rr, tune by pcm4less, LT, 3" exhaust, 3" ORYP, no cat,58mm TB, SVO 36 lb inj, egr and air pump deleted, 3.42 gears.
Mods in process:
Having the tranny rebuilt for racing and installing a 3600 stall. Will also be installing a ported by LLoyd Elliott intake.
How close will I be to 11's and what else should I do to get there?
Old 02-11-2008 | 06:55 PM
infinitebird's Avatar
Why would you port the intake before the heads? lol
You're going to need a good h/c setup to get 11s, or nitrous.
Old 02-11-2008 | 06:59 PM
mack's Avatar
Well I had an extra intake laying around and my heads have a "mild P/P" from the engine rebuilder. Nothing all that speacial. Figured it would still flow better than stock w the ported intake. Is a waste of time to switch it out? Not worth the gains?
Old 02-11-2008 | 07:06 PM
well, it can't hurt but the intake doesn't really become a restriction until your heads are ported.
It will take more than a mild port on the heads and a good cam to get 11s.
Old 02-11-2008 | 07:12 PM
grn95t/a's Avatar
spray that thing!!!!!!!!!!
Old 02-11-2008 | 08:18 PM
BOLO's Avatar
A good heads/cam set up or some juice will get you in the 11's.
Old 02-11-2008 | 08:43 PM
Taubr Unit's Avatar
Spray a 150 at it and hold on, then collect ure 11 sec. slip at the end!!
Old 02-11-2008 | 11:07 PM
96lt1m6's Avatar
NXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNX NXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNXNX NXNXNXNXNXNX
Old 02-12-2008 | 07:42 PM
gtkiller97's Avatar
....11 sec lt-1 here with cam, 100 shot and horrible 60ft
Old 02-12-2008 | 08:00 PM
Checkmate007's Avatar
Nitrous is good... I would rather be caught sucking on my bottle than,
Quick Reply: How can I get into the 11's?
