Thoughts of new LT1 Intake Design
based on the lsx design in what aspect? the more rounded runners?
sounds like it would flow like a total beast.
the only problem is finding out a way to make it.
Where Edelbrock reworked the original was to add more area under the runners to improve torque. It is kinda hard to add runner length and get everything to still fit under the lip
It actually flows less to gain more in the area of torque. Besides that the stock one can be ported to improve flow.As far as composite vs. non ferous metals. R&D alone will require millions of dollars if it is going to be certified and mass marketed. Since the intake design is dry you could go with a composite which would free up some artistic flavor in design.
So if you can come up with something and have an engineer approve etc. the best thing to do would be to sell your design after you get it patented to an aftermarket company. That way you have as little as possible out f your own pocket and they can foot the bill for the tooling and machinery etc needed to build it. Good Luck!
Stumbled on this anyways.
Also, Wilson must know something to be using Aluminum.
http://news.hspn.com/articles/755/1/...old/Page1.html
I think too many people get caught up in trying to reinvent this wheel solely becauce the gen 1 and gen 3 motors benefit so much from intake swaps. Guys claim vast benefits from single plane swaps on the LT but I fail to see that in proven results.
The LT intake certainly leaves room for improvement, it is not perfect, but the reason there are no viable alternatives at this time is because the gains will not be easily found and likely wont fit under a stock hood. If it was as easy as the average enthusiast trying to make an LS type intake it would have been done 100 times already. Factr is even companies like Lingenfelter and Edelbrock have tried to crack this and have not produced anything really truely worthwhile.
