madman solid motor mounts
Old Jan 29, 2008 | 01:06 PM
mean94lt1's Avatar
Default madman solid motor mounts?????
has anyone used the madman solid motor mounts with a stock k member and power steering? if so please post up some pics
Old Jan 29, 2008 | 02:15 PM
skippydn's Avatar
I dont have any pics. I will try and get some tomorrow. I am running a stock k member and power steering. No problems.
Old Jan 29, 2008 | 02:20 PM
mean94lt1's Avatar
ok well my steering shaft wont fit on the rack the motor mount is in the way here is a pic
Old Jan 29, 2008 | 02:56 PM
black383's Avatar
not to highjack, but how is it with solids, doesnt car shake to much?
Old Jan 29, 2008 | 03:07 PM
skippydn's Avatar
Only when I let out on the clutch. I got a spec stage 3 and spec flywheel.
Old Jan 29, 2008 | 03:12 PM
black383's Avatar
so do i..... hmm i need to see what kinda are in there first...
Old Jan 29, 2008 | 05:25 PM
foggedz's Avatar
Wow that sucks. I have these mounts also that I was going to be using with the stock power steering rack. I had eye balled everything, and I thouht it would fit. But by the looks of your picture there isnt anyway. He is usually in the Drag Racing forum. You might want to try and post this there.
Old Jan 29, 2008 | 10:46 PM
Speed Density's Avatar
hashtagBMW
No way in hell I would run solids on a street car.
Old Jan 29, 2008 | 10:48 PM
mean94lt1's Avatar
yeah it really sucks i talked to bryan from madman on the phone and he said that i could just cut that gusset off but i believe that would make them very weak...customer service was poor also he said nothing when i told him about my problem he sdaid o we never put them on a stock k member car????
Old Jan 30, 2008 | 12:31 AM
socal's Avatar
send them back, they didn't work and theres nothing saying a stock k-mender wouldn't work w them is there
Old Jan 30, 2008 | 12:35 AM
Steve in Seattle's Avatar
do your tires EVER leave the race track? If so... get poly mounts and be happy.
Otherwise you need to try a LS1 steering rack (moves the base outward), or go to an aftermarket rack (like a flaming river), or maybe relocate the stock rack and install bump-steer corrections.... all in order of difficulty of course.
Old Jan 30, 2008 | 12:45 AM
TwoFast4Lv's Avatar
Damn I have the stock Steering. I guess I can't use them this year.
BTW ALL My dealings with MADMAN have been great
Old Jan 30, 2008 | 12:58 AM
foggedz's Avatar
And that makes no sence, because these are only designed for the stock k member. The additional pad that is welded on the drivers side mount will only work if your using the stock k member. I have a PA k-member that I had to modify to even get these solid mounts to mount up.
But anyways I went out and bolted everything together and took some pics. I was able to get everything to bolt up an the shaft did not hit. I also turned the wheel lock to lock and nothing hit. Sorry about the big pics.
Here is a front view
view from the top
Picture of a modified PA k-member so that I could use all the bolts designed into the motor mount.
Old Jan 30, 2008 | 02:35 AM
ok, so anyone know what's going on with the first pic? Can you take a front shot and a shot further back?
Is it bolted to the right spot? (ya never know...)
It's clear the problem mount isn't oriented the same and foggedz's mounts.
Old Jan 30, 2008 | 06:44 AM
mean94lt1's Avatar
your mounts are welded different than mine my gusset goes all the way to the bottom ill post up some pics later
Old Jan 30, 2008 | 10:13 AM
skippydn's Avatar
May I ask why?
Old Jan 30, 2008 | 12:21 PM
foggedz's Avatar
Yeah, after taking a closer look at your pic, it does appear your gusset is different than mine. Where did you order the mounts from. When I ordered mine from Thunder racing they said I could send them back if they didnt work.
It seem to me that the jig used to make these mounts must only have the mounting points for the motor, and the K-member built in. The gusset is probably added afterwards, and done a little different on each set.
As far as the comment about solid mounts being a bad idea for a street car. I have had some form of solid mounts on my car for 2 years, and pefer them over any other type of mount.
Old Jan 30, 2008 | 02:58 PM
mean94lt1's Avatar
ok thanks for the input guys i work at a machine shop so i think i will cut that gusset out and re weld it in
Old Jan 30, 2008 | 05:16 PM
Whitez406's Avatar
I prefer a solid over a poly anyday. Some ppl tolerate more then others if you prefer polys you use them, he wants to use solids, so lets stick to the fitment issues instead.
Old Jan 31, 2008 | 01:19 AM
foggedz's Avatar
If it makes you feel any better I just installed the Madman "MADMAN LOWER REAR SHOCK MOUNT KIT", and the hardward that was included was not the correct size. The bolts that were sent about an 1/8 to small in diameter, and the shock would have bin able to bounce all over the place. I had to go out and buy new hardware and drill out the holes in the new Madman mount.
