94 Bird Front Seal Oil Leak
My 94 LT1 likes to coat the garage floor with Mobil 1. I finally cleaned the motor and put it on jackstands looking for the source of the leak. It is leaking in the front of the motor. It appears that there is a trail of oil coming from the back of the opti. My ride has 70K on a rebuild. Is this a normal spot to leak? When I tear into it, will it be a problem to replace all three front seals? Are there any special tools I will need besides the normal garage tools? Finally, are there any speedy sleeves for the crank and water pump(if it is even an option) that I should be using?
