LT1 timing gears without waterpump drive?
Old Feb 4, 2008 | 04:13 PM
Karl Ellwein's Avatar
Originally Posted by 96capricemgr
You did not read what I am writing, I said the arguments people pose are wrong it is strong and it is not expensive, not that everyone should invariably stick to stock.
I also went on to tell Jake what to look for to find a chain that will fit.
Dwayne, I read and I re-read and you are calling people shysters for recommending $80 billet timing gear sets which is just wrong and bad manners and you want someone to buy a certain $30 comp cams timing set.
And the question is, if he doesn't buy the $30 comp cams timing set will you call him an idiot tomorrow?
Karl
Old Feb 4, 2008 | 05:35 PM
jakesz28's Avatar
Jake, since you say the opti drive is welded up as well as the WP, all you need is a timing set for a factory roller cam setup. Lots of choices, one shyster will tell you to buy a $80 billet but I have it on good authority that a $30 Comp one will work just fine too.
Going rear mount on the distributor?
Yes I'm going with a crank trigger and low profile crab cap distributer. I'm going to be turning this thing to 8000. So the ecm and opti are gone.
Old Feb 4, 2008 | 06:14 PM
fergymoto's Avatar
curious what the idea of using a new cam sprocket does? (vortec) thanks
Elminates having a water pump drive gear on the back of your cam sprocket.
Old Feb 4, 2008 | 06:25 PM
96capricemgr's Avatar
Karl
It was not the fact he recommended a $80 timing set that caused me to refer to the person in question as a shyster.
If I wanted someone to buy a specific $30 timing set I would have given a PN, I was just saying that there is no reason to spend a fortune.
Old Feb 4, 2008 | 09:17 PM
97LT1's Avatar
While I respect your opinion on this, you have really taken a sour approach to disagreeing with people. You act like if people don't agree with you, that they are complete fools. You tell people that don't agree with you, that they are ***suming, and not in reality, and shysters etc. Grow up man.
Old Feb 4, 2008 | 09:39 PM
mean94lt1's Avatar
Originally Posted by dirk70301
I'm building a 383 LT1 and will be using an eletric waterpump . I was wondering if a SBC non LT1 timing set will work . It is worthless for me to buy a lt1 gearset for hundreds of dollars if I will not be using a waterpump drive.
this was the guys question he simply didnt want to spend the money on a stock set when their $200 plus when he can get a billet true double roller for half the price so....yes you can use a factory roller timing set if you have a 95 up timing chain cover and opti...
Old Feb 4, 2008 | 09:47 PM
thebufenator's Avatar
Well, my experiance is this:
When building my LE3 383, I purchased a new stock timing set.
After I got the parts for the vented opti conversion, I realized I could go with an
SBC double roller chain.....
Well I fitted the stocker set on, and it had a bit of play in it. Too much for me to be happy. So I ordered an $87 Cloyes double roller. Fits nice and tight with no play.
So I am happy.
Old Feb 5, 2008 | 05:12 AM
AGAIN a stock set is NOT $200, not half that.
Cloyes sells an oversized crank gear to tighten a stock chain, I bought one from Karl for like $24 shipped when he was selling parts, think he stopped now though. It still sits on a shelf but I have it.
Old Feb 5, 2008 | 07:07 AM
mean94lt1's Avatar
if you get a set form gm yes it is its 225....as for a local parts stores chain i wouldnt trust it if i had money in my bottom end i worked at a gm dealer and seen alot of local parts store chains break....the gm chain is a good piece but it is expensive...and if the stock chain is stretched why would you reuse it??
Old Feb 5, 2008 | 05:57 PM
Are you actually quoting list prices you know there are countless places that will sell at WAY WAY under list.
https://ls1tech.com/forums/showpost....0&postcount=13
to give an idea.
You must be quite a newbie if you actually pay list. Dealership markup is routinely 100%+. Sometimes you can even find guys selling at cost+10%.
The LT4 ED set is over $200.
Old Feb 5, 2008 | 10:14 PM
mean94lt1's Avatar
to give an idea.
your right im a newbie i only work as a mechanic and worked at a gm dealership i dont know what markup is or anything your right im done arguing the simple point is yes he can run the double roller for a factory roller engine
Old Feb 6, 2008 | 06:13 PM
  #32
So you deliberately and knowingly quoted the most ridiculously high price you could come up with rather than a reasonable one in order to try and suit your argument?
Old Feb 6, 2008 | 06:34 PM
  #33
bigdan1's Avatar
for once that i can bring something here .....
I plan to put an EWP on my LT1 ( 95 )
i bought a cloyes true double roller t/c....installed the set put the cover on without gasket to verify clearance ( had some playdoo putty on the chain )
it was rubbing !!!! I grinded down the reinforcement bump ( in the cover) that is facing the cam gear ...I had to grind it to the point that it is flat with the rest ....and over this I had to put two gasket thick so i could obtain around .060 clearance ....so it is NOT a direct fit ....some work involved!
installed my dowel pin at .675 to compensate added thickness!
hope this helps out!
Dan
Old Feb 6, 2008 | 08:24 PM
  #34
mean94lt1's Avatar
you really need to letr it go the guy asked a question that isnt evenclose to what your continuing to argue with me about and just so you know that is what a gm dealer would charge and that is where most people would go so grow up and let it go damn you argue and make an *** out of everyone and you dont stop until you won i said i was done arguing why couldnt you just let it go
