HELP!! Need Length On Pushrods
Old Feb 3, 2008 | 08:50 AM
94_formula_lt1's Avatar
Default HELP!! Need Length On Pushrods
guys im having issues with the psuh rods..i bought a lt4 cam kit and i was wondering what size push rods i needed for the car if you guys can help me id greatly appreciate it
Old Feb 3, 2008 | 09:34 AM
BOLO's Avatar
Stock length will be fine. Maybe better to upgrade to hardenned heatreated pushrods for durability.
Old Feb 3, 2008 | 09:59 AM
Rocky70304's Avatar
Yeah, stock length pushrods are the right size. agree with the upgrading to hardened ones though, cheap insurance
Old Feb 3, 2008 | 12:06 PM
Get all of the performance your engine can produce with these durable pushrods designed especially for high-lift cams. Trick Flow pushrods are available in both 5/16 in. and 3/8 in. diameters. They feature .080 in. wall thickness and are formed from 4130 chromemoly steel. These one-piece Trick Flow pushrods are heat-treated for use with guideplates. They close their tips, and then the oil holes are drilled and chamfered to .093 in. to prevent stress fractures and cracks
is these the right 1s that i am looking 4?
Old Feb 3, 2008 | 12:34 PM
speed_demon24's Avatar
Heat treated pushrods do nothing for durability if you aren't running guideplates. Chromeoly is a different story though.
