Coil pack conversion kit
Old Feb 15, 2008 | 06:45 AM
  #41
Paul Bell's Avatar
That's MISTER MODERATOR
You can only buy the LTCC system from Bob Bailey:
http://www.bailey-eng.com/LTCC.html
You'll still need to purchase a set of eight LS6 coils, fabricate coil brackets and a set of plug wires.
Old Mar 18, 2008 | 09:08 PM
  #42
sly_cam's Avatar
question , how does this stand up to water , regular opti spark and water don't mix, does this take care of that problem or is it still an issue !
Old Mar 18, 2008 | 09:33 PM
  #43
96capricemgr's Avatar
The opti is retained with the Delteq and LTCC it is just no longer used for spark distribution.
Real problem with the opti is owners not the opti.
Old Mar 19, 2008 | 06:51 AM
  #44
Paul Bell's Avatar
My car is a daily driver and I've driven in some fairly bad weather. I've never experienced any issues with the Opti. The 315/35/17 DR's are another story, especially in the snow
Old Mar 19, 2008 | 09:54 AM
  #45
seawalkersee's Avatar
So...what would be the problem with a stand alone style LS1 ignition? It looks like the guy out of Eastern MO has done this, but why could one not do this with the factory style ignitions off of an LS car?
Chris
Old Mar 19, 2008 | 06:06 PM
  #46
People do not seem to understand that the opti is RETAINED with both the LTCC and delteq. I am not saying either is bad BUT when you stop and look at just how fast guys are going with the opti and how many of the guys swearing it is crap are inexperianced kids a "new truth" emerges about whether it is worth spending $600 on an "opti eliminator" kit that really only takes the duties of the $100-150 cap and rotor.
Let me put this another way. If a LTCC or Delteq "fix" an ignition problem then the problem was either with the $100-150 cap and rotor or the $60 sparkplug wires. The cap and rotor are WEAR ITEMS that should be part of periodic tuneups, same for the wires. The "optical" functions of the opti are still needed so that the pcm knows where in rotation the engine is.
