Location of Fuel Pump Relay...
Hey guys, my buddy has a 95 Z-28 Vert that he is working on. He bought it with a chewed up wiring harness, which someone had already removed. He bought a painless harness for it and is now down to just a few more connections/wires. The main one he cannot find is the location/connection for the fuel pump relay.
Anyone know where this thing is? He has been crawling around like crazy under the car to no avail. If any of you know EXACTLY where it is, chime in.
Thanks.
Thanks.
I may be wrong but isnt it under the hood on the radiator core support located inside that black plastic box that says Relays/Fuse?
No, now that I think about it, its a big sucker and I remember having problems with one that was located behind the drivers side kick panel. My bad.
sorry for the late responce but if you haven't found it yet the fuel pump relay is located right by the plug-ins for the computer. be sure to use the correct part number for the fuel pump relay (it's in the manual)
