Max compression on a street car?
Should be significant if you can do it without inducing timing retard.
Worth a good 20rwhp up top even with a mild cam.
Hell, just switching to thinner head gaskets is worth 5.
FWIW, I'm up around 12.1:1 with my new setup (zero-decked -4cc pistons) on pump gas.
I had 11.3 with the previous setup (stock deck and pistons) on pump gas.
Both setups use a cam with a very aggressive LSA.
If you're just running back and forth to the store then yeah run pump gas..... if you are going to the track run 108 or 110 or other premium race fuel. It's cheap insurance.. (Errrr rather expensive insurance at 10.00 a gallon)... but still worth it...
I would not tune a DD for race fuel though,
I'd either run a separate tune at the track or not run race fuel at all.
I do however tune for premium pump gas (92 Octane in this part of the country)
