Question about Cloyes timing chain
Old Feb 16, 2008 | 01:01 PM
Black96Z's Avatar
Default Question about Cloyes timing chain
To run a Cloyes timing chain I would have to convert to a EWP, remove the waterpump drive, and remove the CPS reluctor. Is that all that needs to be done for clearencing for a 96 camaro?
Also, on the summitracing web site, they list 4 different chains; CLO-9-3145, CLO-9-3145-10, CLO-9-3145-5, and CLO-9-3145-15. Which one would I want to use?
Old Feb 17, 2008 | 12:02 PM
Black96Z's Avatar
anyone?
Old Feb 17, 2008 | 05:47 PM
Ed Wright's Avatar
9-Second Club
That is all I had to do to mine.
Old Feb 17, 2008 | 11:01 PM
bigdan1's Avatar
are you asking about a true roller double timing chain set?
Dan
Old Feb 17, 2008 | 11:08 PM
thebufenator's Avatar
you may need to clearance the timing cover
Old Feb 17, 2008 | 11:40 PM
Black96Z's Avatar
This is the timing chain I was thinking of using.
http://store.summitracing.com/partde...5&autoview=sku
Old Feb 18, 2008 | 07:14 AM
I think thats the one I used, should work fine.
Old Feb 18, 2008 | 09:42 AM
Ed Wright's Avatar
9-Second Club
http://www.sdparts.com/product/SDCS1...TimingSet.aspx
Check out this one at Scoggin Dickey, it is what I use. Nices piece, and clears my covers just fine.
Old Feb 18, 2008 | 11:19 PM
matt94z's Avatar
You'll just need the 3145 unless you've had your block line honed. I had to run the 3145-10 since mine was...
Old Feb 19, 2008 | 12:02 AM
SS RRR's Avatar
Village Troll
Why would that be?
Old Feb 19, 2008 | 05:40 AM
leadfoot4's Avatar
Originally Posted by SS RRR
Why would that be?
Because line honing the block reduces the distance between the crank and cam, therefore a shorter chain is needed...Usually around 0.010-0.015" shorter.
Old Feb 19, 2008 | 06:03 AM
SS RRR's Avatar
Village Troll
Interesting... mine was line honed and I'm using a standard length Cloyes double roller... fits fine w/ no noticeable slack.
Old Feb 19, 2008 | 10:08 AM
leadfoot4's Avatar
Well, let me rephrase that...It MIGHT change the distance between the cam and crank, depending on how much material had to be removed in order to do the job.
Old Feb 19, 2008 | 10:21 AM
Ls1Bait's Avatar
^^^^ Yea you would talk to the machine shop and ask them what chain would be best in relation to material taken off.
Old Feb 19, 2008 | 11:34 AM
96silverram's Avatar
Ed,
That is a nice looking piece for a very reasonable price. I have been looking for a good DBL-roller that I can just plug & play. It looks like your saying the unit does not require any additional work with the stock 96/97 timing cover. I don't want to modify my cover, just want to install it and go
Old Feb 19, 2008 | 04:01 PM
matt94z's Avatar
Some have to, some don't. Mine had more slack than I was comfortable with.
Old Feb 20, 2008 | 12:02 AM
bigdan1's Avatar
I installed the same cloyes set on mine ( 95 LT1) and i had to modify my cover ...
tried without gasket : no clearance
tried with two gaskets : still no clearance
I had to grind down all the cover reinforcement that is around the opti hole so that the cam gear section would clear .... now i have around .045 clearance ...better be safe then sorry!
Dan
Old Feb 20, 2008 | 08:53 AM
Ed Wright's Avatar
9-Second Club
Both of mine have 1996/1997 timing covers, no clearance problems with either. Cleared with no gasket before assembly. The 383" has been run three or four years, the 355" all last summer. Have them both apart right now, no problems. If anything ever touched it would be evident. Maybe the OBD2 cover has more room? Don't own an OBD1 cover, so can't say.
Old Feb 20, 2008 | 08:55 AM
Ed Wright's Avatar
9-Second Club
Originally Posted by 96silverram
Ed,
It has more adjustment than the Cloyes, and a Torington-style bearing on the back of the cam gear, so no wear on the block, both gears are billet, not cast. Made in Austrailia, very nice setup.
Old Mar 19, 2008 | 04:01 PM
Ed,
Thanks for the product endorsement I went ahead and purchased the item. I will definitely say it's very nice for $95.
