Oil pressure ?
Old Feb 19, 2008 | 05:56 PM
LT4hotcam's Avatar
Unhappy Oil pressure ?
Today while i was driving, i pulled up to a light, and my check gauges light was on, i looked and my oil pressure was on the red, but my temp was normal, and everything else was normal, my car sounded okay, and it was idleing good, then when i took off it jumped to 60 PSI and the light went off, i was shiting bricks, i went home and let it cool off, now its back to normal psi. Has this happened to anyone before?
Thanx, and sorry for the long thread.
Old Feb 19, 2008 | 06:50 PM
Dragframe's Avatar
Mine gets clsoe to the red... But it also flickers around a lot. I need a new sending unit.
What kind of oil do you use?
Old Feb 19, 2008 | 07:26 PM
94Z28-MSTGKLR's Avatar
If you run 5w-30 it should only run about 18 psi at idle which is really close to the red at warm temp's. It sound like the sending unit got stuck. If everything is working like normal now, and the oil level is normal I wouldn't worry about it.
Old Feb 20, 2008 | 02:16 PM
LT4hotcam's Avatar
I run 10w-30, About how much does the part cost.
Old Feb 20, 2008 | 02:48 PM
I'm not real sure for an aftermarket one, but I know an AcDelco will probably run 60-80 bucks. I work for a chevrolet dealership so we don't deal much with aftermarket parts. If you need me to I can find out tomorrow at work and post you back so you don't go running around town looking for one. How close to College Station do you live?
Old Feb 20, 2008 | 03:40 PM
LT4hotcam's Avatar
Alright Thanx
What is the part called exzactly, i need whatever makes the oil PSI gauge work.
Old Feb 21, 2008 | 04:33 AM
mtperformance's Avatar
Originally Posted by LT4hotcam
Alright Thanx
Its called the oil pressure sending unit and it is located behind the intake manifold on the back of the block and it cost about $20.
Old Feb 21, 2008 | 10:43 AM
Z-ROC28's Avatar
I just replaced the sending unit on mine. I was reading kinda low too, do these cars idle at 25psi or so? And also, my gauge needle does not move smoothly. It almost jumps like a clock does.
Old Feb 21, 2008 | 03:47 PM
LT4hotcam's Avatar
It was doing it again today, in park its right at the first quarter then if i put it in drive or reverse it go's to the red, and the light comes on. Where do they sell for 20$, and is it the one with the long wire that goes to the oil pan on the drivers side, right above the drain plug. I currently run 10w-30 regular oil, not synthetic, would going with a different weight help it out?
Thanx
Old Feb 21, 2008 | 10:22 PM
Ws6Rob's Avatar
+2,get it form carquest.
Same thing happened to me,turned out I was just a Quart low felt pretty dumbBut I'm glad it was a easy fix
Old Feb 21, 2008 | 11:50 PM
Thanx
There about $20 anywhere . It is located in the block directly behind the intake manifold. The one in the pan is the oil level sending unit.
Old Feb 22, 2008 | 03:27 PM
LT4hotcam's Avatar
[QUOTE=mtperformance;8765809]There about $20 anywhere . It is located in the block directly behind the intake manifold. The one in the pan is the oil level sending unit
how much does the this one cost and what does it control, or do. thanx
Old Feb 22, 2008 | 06:27 PM
Sorry I never got back to you. My wife just had our third baby. BY the way I did check just out of curiousity and they are 45 bucks from my dealership, but I could have picked it up for 12 dollars.
Old Feb 22, 2008 | 06:38 PM
LT4hotcam's Avatar
Man thats a good price, they seel them at autozone for 20.00 bucks.
Old Feb 23, 2008 | 12:24 PM
Yea but the only reason I could get it for that is because of my gm discount.
Old Feb 23, 2008 | 12:59 PM
Redbird1993x's Avatar
LT4hotcam, How do you like that cam? Got any track times?
Old Feb 23, 2008 | 02:27 PM
LT4hotcam's Avatar
I dont have any track times, but i plan on going once i get my tranny fixed with my new Yank SS 3600. I hope i get a decent time, my car fells pretty good at WOT.
Old Feb 24, 2008 | 06:59 AM
Burning Rubber's Avatar
Anytime I have had an issue with oil pressure I always test the gauge in the car against a mechanical gauge before I do anything else.
Old Feb 24, 2008 | 03:49 PM
Excellent idea! I used to permanently mount one under the hood of all vehicles for comparison.
I installed a Yank SS3600 in mine when I had the tranny redone. Works well. With that and some new MT drag radials I am hoping to shave my 60' from 2.0 to ....well lower lol! Hopefully break into the 11's.
