nitrous or cam and rr?
Old Feb 24, 2008 | 12:23 PM
jakesz28's Avatar
Nitrous is going to be the bigger bag for the buck. You can also start with a kit from dynotume for $370 and add some accessories as you fill the need. A 150 shot should be good for around a second off your et.
Old Feb 24, 2008 | 04:38 PM
GIVE EM' THE BIRD's Avatar
^good point. its all about what you want the power add for. spray is/can be cheaper and quicker to setup with probably as good or better results than the cam but with the cam you are n/a and if you want to be faster you can spray it after the cam. and btw, i would go with headers before the cam.
Old Feb 24, 2008 | 05:17 PM
I8ASaleen's Avatar
Headers, then all the supporting mods (bigger TB, CAI, free flowing exhaust, RR's, lifters, springs, etc...) then spray, then a cam
Old Feb 25, 2008 | 01:52 AM
97badass's Avatar
ttt...any cam suggestions?
