open loop (idiot mode)
ive replaced :
MAP sensor
coil
ICM
IAC
plugs
wires are new except one of them is heat cracked
fuel filter is fairly new but not hung on its clamp
TPS is about 8-10 months old
i cleaned the MAF because i had a K&N
EGR is new but im starting to wonder about the solenoid
im stumped. i swapped out my O2s (bosch) for my old oem ones that were sitting and it still stalls right after start up/once every drive cycle at a random idle. also the starter started grinding and spinning freely sometimes after this
it goes into limp home mode and ive been driving it like this for weeks.could the battery being 7 years old and still holding 13 volts cause it? i heard the ampage could diminish after a few years.
or the VSS?
coolant temp sensor?
Anyways, a bad PCM/ECM is what'll throw a car into Limp Mode. On an ECM, remove the whole EPROM and you'll see what Limp Mode is all about.
That one wire could be bad, not sure. The starter sounds like it's got it's own gremlins, and the battery SHOULD be fine, but it shouldn't have 13vs. I think they're 12.4v. So, alternator could be overcharging. It'd have to be way overcharging I'd think to throw the whole system out of whack.
check your o2s
o2's would be a good thing to test. But not sure if the o2 would be able to make it go back into open loop (far as i kno, they won't).
