A few pictures of my nitrous install...*UPDATE* 3.5.08
Old 02-29-2008, 12:02 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Originally Posted by jakesz28
I would recommend changing the way the side or perimeter spray bars are teed together and plumb them with a Y fitting. The side that has a straight thru shot in the tee tends to flow more then the other side. I would hate to see you have a problem with that but at the same time I don't really know what your planning to spray.
Mike
I've heard quite a bit about that also in the Nitrous section. Noyzee was talking about having flow issues with his. There was a thread called what plate or something like that not too long ago in there.
Old 03-03-2008, 08:15 AM
8 second mod
Noyzee's Avatar
yup, that "F" style fitting on the front and rear for the side suply flows all to the end smooth 90* fitting, there for sending all spray and fuel to one side of the intake, there for creating poor flowing and distribution.
you need to make lines for it in more of a "Y" style inorder for it to flow correct.
looks good tho
Old 03-03-2008, 03:05 PM
hashtagBMW
Speed Density's Avatar
Im hoping the Tee's work for a decent amount of gas (200hp ish) and then ill go from there.
Old 03-03-2008, 03:14 PM
8 second mod
Noyzee's Avatar
doesnt matter how much or little spray you run, it all goes to one side there for possable issue . i flow tested with like 12 jets in it or somthing super small and 90+% went to the end side and did not flow to the other side in turn creating lean and fat cylenders. good luck if you keep it that way. keep an eye out on the plugs on 1 side
Old 03-03-2008, 05:15 PM
grn95t/a's Avatar
very Nice!!!
Old 03-03-2008, 06:17 PM
Lt1junkie's Avatar
Pretty sick setup... What kind of shot are you planning on shooting
Old 03-03-2008, 06:29 PM
hashtagBMW
Well at the pinacle of it all im setting the jets at 300hp.
At this point im going to swap lines over. Made a few calls to confirm the tee theory so its time to change.
Old 03-03-2008, 07:41 PM
BADHAWK51's Avatar
Thats a good looking set up you got. Nice job on the install also.
Jeff
Old 03-06-2008, 12:24 AM
hashtagBMW
Some more from today.
I dumped the Aeromotive Y and swapped to a Magnafuel one, reason being clearance. Both stages FPSS are installed now too.
Ill need to cut the cowl a wee bit, nothing to bad.
So basicly at this point I need to run my Vaccum sysytem, install a dipstick and set the throttle linkage up. Start it, find the leaks and the its tuning time.
Tony.
Old 03-06-2008, 12:22 PM
8 second mod
Noyzee's Avatar
so you didnt trust me hey. lol glad your swaping, id hate to see you burn it down over $10 worth of lines.
Old 03-06-2008, 01:05 PM
hashtagBMW
Na, I remember that thread in admin section. Reverted back to that and got some more solid info.
Wonder if they make a hardline y setup?
Old 03-06-2008, 01:16 PM
  #32
8 second mod
Noyzee's Avatar
it all depends on room.
you can see here how i made mine work. just bent them up with vinny and badda bing
Old 03-06-2008, 01:40 PM
  #33
Tony Shepherd's Avatar
Looking damn good Tony! Lets compare engines! LOL!
Old 03-06-2008, 02:42 PM
  #34
FASTFATBOY's Avatar
Tony, what size tire and what rpm do you go through at?
David
Old 03-06-2008, 04:39 PM
  #35
hashtagBMW
So true Shepherd, so true!
Old 03-06-2008, 04:57 PM
  #36
LT1Formula007's Avatar
Looks Bada$$
Keep up the hard work....
Old 03-06-2008, 06:23 PM
  #37
jakesz28's Avatar
You try to help someone out and they tell you your wrong. Oh well.
It's nice seeing you make the change. Better safe then sorry when on the bottle.
Old 03-06-2008, 06:37 PM
  #38
hashtagBMW
Jake,
I didnt say anyone was wrong, I just wasnt sure a change was needed, 'yet'.
Old 03-06-2008, 06:44 PM
  #39
jakesz28's Avatar
Hey I was just joking sorry about that. I better be carefull with what I type sometimes it comes off a little wrong. It's looking good and I wish I was that far along.
Old 03-06-2008, 06:46 PM
  #40
hashtagBMW
just put a smilie after everything, that alwasy softens the blow. lol.
Yea, im trying to find all the time I can to work on it, our season opens the 30th and Id like to just have the car out there, not race.
Its really close now, I know this because there is a bunch of lil **** that needs done.
Quick Reply: A few pictures of my nitrous install...*UPDATE* 3.5.08
