mid lengths vs longtubes?
cliffnotes:
LTs=more low-end TQ gain but ground clearance issues.
Mids=slightly less low-end TQ gain but no clearance issues
cliffnotes:
The reason I don't want LTs is just due to I don't really want to dick with them lol I'm not one to "go big or go home", for me, me car rocks, but an easy install of something I'll gladly go for like shorties or mids.
The length of the primary pipes also affects torque. Where diameter affects the torque peak relative to rpm, the length affects the shape of the torque curve. Longer primaries provide more torque below the peak and reduce it past the peak. Shorter primaries provide more torque above the peak at the expense of below-peak torque. More torque in the low- to mid-rpm range is important to rodders who want that feeling of seat-of-your-pants performance on the street. Longer primaries also reduce the chance of escaping exhaust's being drawn back up another pipe.
all headers are a pita on these cars or any v8 for that matter. you still go through the same work between shorties and lt's just the shorties will be slightly easier to get lined up. imo for the day of work you have to go through the extra 30 min getting the lt's lined up will defently be worth. the only real advantage shorty vs lt is that the shorty will hook up to stock y-pipe, and they should defently pass emmissions no problem, depending on which brand of course.
