Are taller valve covers needed?
Old Mar 2, 2008 | 11:38 AM
94blownz281's Avatar
Default Are taller valve covers needed?
i have crane gold series 1.6rr,hotcam,Lingenfelter dual valve springs. I sold my s-trim and am either going with a T-trim or procharger. i have a set of valve covers like the ones they sell on ebay that are polished up and are all smooth. pretty sure they are the same height as stock covers. will i have a clearence issue? before just had stock cam,1.6rr and single springs.
Old Mar 2, 2008 | 12:15 PM
slick1851's Avatar
Mind posting wich valve covers you have?
Old Mar 2, 2008 | 12:57 PM
Digi camera is down right now. they are the ones you can find on ebay that are smooth and polished except mine have LT1 craved in the middle of them and painted black.
Old Mar 2, 2008 | 01:18 PM
Formula350's Avatar
Would you say they are modified stock, or a completely different casting?
Old Mar 2, 2008 | 02:09 PM
last time i saw a stock LT1 valve cover was back in 1997 so i have no clue. if you got a second go on ebay and look up LT1 valve covers and you will see like 30 listing for polished LT1 valve covers. thats the samething i have.
Old Mar 2, 2008 | 02:22 PM
porksoda's Avatar
Shouldn't have clearance problems with the Crane Golds. The Pro magnums usually need the clearancing.
Old Mar 2, 2008 | 02:41 PM
even though i will have a higher lift then stock?
Old Mar 2, 2008 | 02:43 PM
porksoda's Avatar
Yes should still fit.
Old Mar 2, 2008 | 02:44 PM
Cool thanks for the help!
