Info on lt1 timing chain
Old Mar 2, 2008 | 03:20 PM
fastlane02's Avatar
Default Info on lt1 timing chain
I'm building a 383 lt1 for a guy and he is running ew and coil packs so the water pump gear and opti spark will not be used.
what choice of timing chains or belt drive setup can we go with.
thank alot
Keith
Old Mar 2, 2008 | 03:21 PM
96capricemgr's Avatar
Most coilpack systems require the opti as a cam position sensor. Which opti you will be using dictates timing chain choices.
Old Mar 2, 2008 | 03:38 PM
fastlane02's Avatar
its a 93 lt1 so its nonvented correct?
Old Mar 2, 2008 | 04:34 PM
SprayedLT1's Avatar
Correct. If you swap over to the 95+ timing cover, you can use a vented opti and a double roller timing set if you want. However, you will also need to either swap out cams or install a longer dowel pin in the stock cam.
Old Mar 2, 2008 | 04:49 PM
I would just use a fresh stock chain then, your choices are very limited by the unvented opti.
The stock chains while much hated are very strong and reliable pieces, taking the WP load off them can only serve to make them more reliable. There is an oversized crank gear available to tighten them some, I can pist the PN if you like.
The hatred of the stock chains is not based on any real problems.
Old Mar 2, 2008 | 05:48 PM
blackz93's Avatar
Stock FTW.
Old Mar 2, 2008 | 05:54 PM
fastlane02's Avatar
alright i'll talk him into just leaving the stocker in then. If he wants an after market one, who makes one. the only one i've found is a gmpp one.
thanks guys
Old Mar 2, 2008 | 06:41 PM
I think Lunati makes one for the unvented setup.
Old Mar 2, 2008 | 06:56 PM
Jditlfm's Avatar
I could use the part number for the stock chain and over sized crank gear if you got the time. The over sized gear not going to be to tight and cause problems will it? Thanks
Old Mar 2, 2008 | 07:49 PM
Cloyes s505 for the gear, don't have the chain number offhand but a search at a parts store site will do the trick for that.
The stock chain is not exactly tight so putting tghe oversized gear on usually just makes it more normal, only ever heard one complaint about too tight and it was not from someone whom's opinion I particularly value.
Old Mar 3, 2008 | 05:07 AM
Jditlfm's Avatar
Thank you.
Old Mar 3, 2008 | 01:34 PM
iceman15's Avatar
I heard the cloyes double chain is pretty good as well
Old Mar 3, 2008 | 01:54 PM
Does it fit with a unvented opti???
Old Mar 3, 2008 | 02:06 PM
iceman15's Avatar
Im not sure if it will work with the unvented but you do need to have an EWP. Ill get back to you on the unvented fitment
