Relocating heavy optima to trunk
Old Mar 3, 2008 | 10:56 PM
BOLO's Avatar
Default Relocating heavy optima to trunk
Does anyone have any info,wiring connections, etc. on relocating the battery to the trunk? any pics would also help, big time! Thanks.
Old Mar 4, 2008 | 08:38 AM
O Holy P's Avatar
I can take some for you when I get home. Pretty straight forward, get a kit from thunder or bmr. I acquired a mounting tray only and got the rest of the materials from various stores. Ran a 1/0 marine grade (+)positive cable from the engine bay to the back well where the battery is now, mount the tray as instructed, got a ground cable from autozone, sanded away some paint/primer from the rear frame rail, bolted it down and painted over it to prevent rust/corrosion, got a gold plated Rockford Fosgate (+)positive battery terminal for the big cable to go into, and put a gold plated distribution block up front, also ran a separate 4g wire to the alt, and to the starter. I'll post some pics for you later on this evening.
P
edit: pics...
Old Mar 4, 2008 | 03:37 PM
96silverram's Avatar
I'm interested in the pics of this also...
Old Mar 4, 2008 | 03:50 PM
Matts94Z28's Avatar
me too
Old Mar 4, 2008 | 04:50 PM
O Holy P's Avatar
edited w/ pics... ^
I used a nylon strap because the battery bolt down bar doesn't hold it tight worth a ****. I'll prolly just take it out later for !weight.
Old Mar 4, 2008 | 08:32 PM
BOLO's Avatar
OHP, thanks for the pics. Now in the distribution block, what wire(s) are going to, where? Please specify, if you can. And on the battery(+) terminal, what other wire is that? where is going to? Thanks, appreciate it.
Old Mar 4, 2008 | 08:36 PM
O Holy P's Avatar
Big *** pink cable > Distribution block. Short red 4g wire out of middle of the distribution block > (+)positive terminal > 4g red wire w/ black heat shrink protector > starter. Far right side of distribution block > 4g red wire to terminal on back of the Alternator.
P
Old Mar 4, 2008 | 09:03 PM
BOLO's Avatar
GOT IT! Thanks again OHP.
Old Mar 4, 2008 | 09:04 PM
I8ASaleen's Avatar
Looks good, I ran mine a bit differently but works the same in essence.
Old Mar 4, 2008 | 09:38 PM
O Holy P's Avatar
Werd, you can do it a few different ways, this is just one of them.
Old Mar 4, 2008 | 09:57 PM
I8ASaleen's Avatar
Ran ground to frame rail under the car, power went directly to the starter, then up to the alternator along with a 8 or 10 ga wire running from battery to distribution block. I like this guys method better, but I'm not ready to pony up anymore $ to what I've already got in this relo.
