highest compression to still run 93 octane
Old Mar 4, 2008 | 06:24 PM
mean_greenZ's Avatar
Default highest compression to still run 93 octane
what is the highest compression ratio to still be able to use 93 octane safely?
Old Mar 4, 2008 | 06:52 PM
lilblackZ28's Avatar
This does have to do with your ?, but what do you run in the 1/4 mile with what is one your sig.
Old Mar 4, 2008 | 07:00 PM
socal's Avatar
i'm going to be running 12:1 when my motor get back thats about all you can do
Old Mar 4, 2008 | 07:09 PM
1redta's Avatar
Default re
I remember hearing 9.4 dynamic compression for 93 octane. you have to input your specific variables for your car into a calculator to figure this. Art
Old Mar 4, 2008 | 07:10 PM
i have no idea cause ive never taken it to the track. but i really want to see what it will run. im hoping it will do pretty good
Old Mar 4, 2008 | 07:11 PM
ckyconan2003's Avatar
11.5:1 WILL run fine. 12:1 is pushing it, but it'll run, you may have issues though.
Old Mar 4, 2008 | 07:13 PM
LT1Formula007's Avatar
Tony Shephard has a 397 stroker with nitrous running 9's and when he's off the bottle he's running 93 octane with 12.8:1 compression. It's all about the tune honestly. I've seen as high as 13.5:1 compression and supposedly had NO issues. Just make sure the tune is right......Don't expect to advance your timing all the way as far as you can and expect not to get detonation or spark knock.
James
Old Mar 4, 2008 | 07:14 PM
sdm1234's Avatar
you'll have to set your cam up correctly for whatever compression you want. it's just like sportbikes running 12.2:1 compression and running 93 octane.
I bet it will run good.Do you drive it year round or just when it nice out?
Old Mar 4, 2008 | 07:21 PM
FASTFATBOY's Avatar
I run 12.6 on Shell 93 octane
David
Old Mar 4, 2008 | 07:26 PM
+1 For Shell 93 octane....
I work for shell, and their gas is alot better than alot of the others....
But like I was saying earlier 12.8+ is safe. Don't be afraid of the compression issue, by going with lower compression your leaving power out on the table... Just my .02
James
Old Mar 4, 2008 | 07:37 PM
Formula350's Avatar
Would it help to get it setup for E85 which is 105oc? I notice when I run around 65gas:35E85 I get more pep out of my car and it's just stock. There's a guy on here who's pretty knowledgable on E85, and since it's alcohol he's said you'll need to change over a few fuel components to account for this. Like fuel o-rings and I think even your fuel pump. Still though E85, 105oc and 30-80cents cheaper than even 87oc!
Old Mar 4, 2008 | 08:14 PM
i drive it every single day of the year unless its snowing or sleeting/freezing rain.
but yea its got almost 138k and it had 114k when i got it about a year and a half ago
and to everyone else thanks for the info. i want to run as high compression as i can on 93. cause that means more power!
and is the shell 93 really better than others? i usually go to hickory point or bp.
Old Mar 4, 2008 | 09:20 PM
TT632's Avatar
You really need to know what your dynamic compression ratio is. Your motor only sees the full static compression if your intake valve closes at bottom dead center or before.
If you have a late closing intake valve (as with a big race cam) your piston could be a 1/4 of the way up the bore before the intake valve closes and your engine only captures 3/4 of the cylinders volume, ie your 12:1 motor has the dynamic compression ratio of 9:1 motor.
Old Mar 4, 2008 | 09:31 PM
BADHAWK51's Avatar
I'm running 12.8:1 here. no issues on the dyno no detonation at all.
Old Mar 4, 2008 | 09:52 PM
transamsam98's Avatar
speaking of compression and 383s does a run of the mill sbc 383 kit work in a lt1?
Old Mar 5, 2008 | 03:21 PM
Puck's Avatar
Like stated, it heavily depends on the tune and the cam. The dynamic compression is the value to watch.
My bike is 13.3:1 and only recommends 90 octane(!).
Old Mar 5, 2008 | 03:39 PM
infinitebird's Avatar
You can go high 12s easy like others have said. If you run into any trouble you can always retard timing a few degrees and that should clear up any problems.
Old Mar 5, 2008 | 03:55 PM
thebufenator's Avatar
My car has 12.2:1
no knock, and that on 8 month old gas.
Its all in the cam and tuning. More compression == bigger cam with more overlap.
Old Mar 5, 2008 | 04:46 PM
blackz93's Avatar
That's alot!
