bolt on questions
Old Mar 4, 2008 | 08:46 PM
mean_greenZ's Avatar
Default bolt on questions
ok what is a good set of underdrive pulleys to buy? what is a good brand of ewp not too expensive? and also a good inexpensive set of 1.6rr's and springs? also i found a 58mm tb on ebay for cheap.
with a ewp, pulleys, rr's, springs, and 58mm tb, how much more hp can i expect from all this? im trying to get full bolt on am i missing anything other than a tune?
Old Mar 4, 2008 | 09:14 PM
97badass's Avatar
dont waste your money on the throttlebody
Old Mar 4, 2008 | 10:02 PM
I8ASaleen's Avatar
Agreed, what are your long term plans for the car b/c just throwing bolt-ons at it with no plan is ok, but you may end up kicking yourself later for using cheap parts when you wanna put in a nice head/cam combo or N2O.
Old Mar 4, 2008 | 10:08 PM
sdm1234's Avatar
gearing/stall would be great as a next upgrade. don't get a TB unless yours is somehow broken.
Old Mar 4, 2008 | 10:17 PM
what size stall with a 3.73 gear? i would like to build it but who knows when that will be
Old Mar 4, 2008 | 10:21 PM
sdm1234's Avatar
beats me haha. i don't pay attention to what the A4 guys say lol.
Old Mar 4, 2008 | 10:26 PM
yea yea. well some of us couldnt find a 6 speed when they were looking for their car lol! i guess a yank or vig 3200 would be for me. i think i will just go for the csr ewp and underdrive pulleys and forget the tb. i still would like rr's though.
Old Mar 4, 2008 | 11:45 PM
M6 Swap's Avatar
anyone have problems w/pulleys and charging system?
Old Mar 5, 2008 | 01:37 AM
94'BLKBRD's Avatar
underdrive pulleys are a waste of money....
Old Mar 5, 2008 | 08:30 AM
Pro_built7's Avatar
^^AGREED. Find the sticky about basic bolt ons for a beginner, it explains why they're a waste of money. its somewhere around here
Old Mar 5, 2008 | 09:11 AM
ToxicFormula's Avatar
Yes a 3200-3300 stall works perfect with 3.73's and its completely streetable too. is your transmission still the stock transmission that came in the car? Do you have any suspension work done? I pretty much have every bolt-on you can think of except for rr and a tubular k-member and a-arms.
Old Mar 5, 2008 | 09:15 AM
kinglt-1's Avatar
underdrive pulleys are a waste of money. if you want to free up a few extra ponies,then look at the meziere electric water pump. takes the load off the motor, but i would wait until your oe pump goes bad or has high miles. Also if you do that, go ahead and freshen up the opti with a rebuild or a new oe unit!
Old Mar 5, 2008 | 08:38 PM
LT14LIFE JT's Avatar
Judging from the mods in your sig, you are at a great starting point. Scorpion makes a great 1.7 rocker that is fairly inexpensive(~$200). I picked up 2 mph and gained over a tenth going from 1.6s to 1.7s. Well worth the money/effort. Add an EWP, 52MM TB, and a stall to that and you're flying. Getting it tuned can be beneficial as well. Weight reduction and suspension don't add horsepower, but do help lower ETs. An igintion box will allow you to adjust timing manually and can help as well. Hope this helps.
Old Mar 5, 2008 | 09:31 PM
LT1_T/A's Avatar
I would go with the bbk 58mm tb, march underdrive pulleys, 3.73's, and 3200 vig. Dont expect much hp from the tb and pulleys because they are small bolt ons. Im not saying not to get them because i did, but they dont give you much.
Old Mar 5, 2008 | 10:39 PM
M6 Swap's Avatar
what brand are your pulleys? do you have any charging problems
Old Mar 5, 2008 | 11:15 PM
slingshot928's Avatar
I have the meziere water pump, 58 mm Holley TB, and all of the other basic boltons with a nice street cam, the cc305. I daily drive my car when I am home from college, which is all summer, and most of the winter. I also have a 3400 stall converter that is really beneficial, with the stock 3.23 gears it really takes off nicely. I really have never liked driving an automatic, my last car was an integra with a 5 speed, but i really do not mind the a4 with stall.
Old Mar 6, 2008 | 03:21 AM
94'BLKBRD's Avatar
Get a torque coverter
Old Mar 6, 2008 | 07:28 AM
blackz6sp's Avatar
Ive got underdrive pulleys on my a4 and it sucks low volts at idle, I wonder if somebody makes a smaller alt. pulley.
Old Mar 6, 2008 | 09:03 AM
Formula96's Avatar
i cut a 1.9 60' on street tires with 3.73's and a 2400 stall(gm truck stall). I didn't lose any streetability with that...
Old Mar 6, 2008 | 10:43 AM
Slowmaro95Z28's Avatar
Suspension is a huge deal when you're looking at 60' times. With stock converter, TRUE street tires, and 3.42 gears i was cutting consistant 1.91 60' with just a few bolt ons. Since then I switched to 3.73's and i have a 3500 stall waiting to go in. When the tracks open I'll post somewhere on here where it got me.
