transmision performance button?
Old Mar 5, 2008 | 10:38 PM
snk-huntr's Avatar
Default transmision performance button?
i have a 95 ta a4 that has this button does anyone know if it locks the converter i know it makes it shift harder and raises the shift points but not sure about the converter thanks.
Old Mar 5, 2008 | 10:40 PM
wg871's Avatar
I use to have a 95 with the transmission perform, I think it changes the shift points a little.
Old Mar 5, 2008 | 10:45 PM
LS1_K1DD's Avatar
IDK if this has any revalence but my truck (2001 V6 Tacoma 4X4) has the same sort of button. Raises my shift points to higher RPM's for max power when towing/racing etc etc. Hope this helps.
Old Mar 5, 2008 | 10:50 PM
infinitebird's Avatar
the performance mode does not lock the converter with any tps % over 25, whereas the normal mode can lock it up till 40% tps.
Old Mar 5, 2008 | 11:17 PM
the_merv's Avatar
I got one of them Performance Buttons too..it's the one I push down to put it into D..
Old Mar 6, 2008 | 01:18 AM
Ralls's Avatar
I have the button. It holds each shift longer with less throttle than normal. Also downshifts with less throttle. It doesn't seem to increase the shift points, but I saw in my tuning program it has it's own tables. So you could be shifting at 5,700 and press the button and shift at 6,000 if you tune it that way.
Old Mar 6, 2008 | 01:46 AM
borninatransam's Avatar
i was thinking the same thing.
Old Mar 6, 2008 | 02:08 AM
Formula350's Avatar
In 93 we got that button too, but we also got a pedal on the floor!! 2x the Performance!
Old Mar 6, 2008 | 06:04 AM
Formula Freak's Avatar
Thumbs up
I have the button as well.I find it to be pretty useful when messing around from a roll.Not sure if it actually makes the car faster from a roll,but certainly feels like it.Makes the car down and upshift more firmly and generally feels more agile when at like a quarter throttle or more.
I also believe it helps with traction too.One time I hit it from a dig with it off,spun like usual.Then with the button on,didn't spin so bad,if at all.Maybe it locks the rear end too?
Old Mar 6, 2008 | 10:56 AM
Formula350's Avatar
We don't have electronic/vacuum locking posi. What it COULD have done was introduce ASR (traction control) to the mix. The less wheel spin the greater performance in theory. That kind of only applies to people who mash the pedal instead of ease into it to prevent it on their own. When fooling around, I mash the pedal just to roach the tires. If I race, I make sure to get the car going a tad and then punch it. The time delay sounds long but it's quite short. Like 75% throttle, then WOT.
Old Mar 6, 2008 | 11:56 AM
1badzee's Avatar
I think I have one too...
Old Mar 6, 2008 | 12:03 PM
th3brandon's Avatar
i have one to but i was told i should unhook it because i have a shift kit,
also i cut the rubber thing off on the shifter so i can pull it down into frist gear i belive on 95 the lowest u can pull it down is 2nd correct me if iam wrong???
Old Mar 6, 2008 | 12:11 PM
StealthFormula's Avatar
I had that on my old '95. Funny thing was everytime I would press the button at the track I would run slower.
Old Mar 6, 2008 | 12:55 PM
Formula350's Avatar
I think that might confirm my ASR theory...
Old Mar 6, 2008 | 02:49 PM
performance mode has nothing to do with asr.
Old Mar 6, 2008 | 02:55 PM
Purple95Z28's Avatar
IIRC Z28's are setup as if the "performance" button is always on.
Old Mar 6, 2008 | 03:22 PM
^ that is not correct it is always off. unless you add the button. there's instructions on shoebox's site.
Old Mar 6, 2008 | 05:59 PM
the_merv's Avatar
You have the 2.73 Rear-End..us with the original 3.23 Rear Cars didn't have that Rubber thing. 2.73's are/were in your Car from the Factory.
You got that too..
Old Mar 6, 2008 | 11:02 PM
1badzee's Avatar
You got that too..
lol i thought i was the only one..
Old Mar 6, 2008 | 11:46 PM
throttlejunkie1's Avatar
I can tell a huge difference when lead footing it around town with the button pushed in. It down shifts with less pedal and holds gears to a higher rpm before advancing...almost feels smoother too.
