Need LT1 cam advice
Old Jul 20, 2003 | 12:03 PM
99 Black Bird T/A's Avatar
Default Need LT1 cam advice
Need LT1 cam advice
Been thinking of swapping an LT1 into my 91 RS. If I do it would be an A4 with 3.73 gears.
Any cam suggestions for a stock LT1 with bolt on's and SLP shortie 1 3/4 headers? I have to pass the sniffer test with the car so it will have to have cats and Carb legal headers. I will do tuning and basic stuff like CAI if I do the swap.
You comments are apprecatied.
Old Jul 21, 2003 | 10:07 AM
TWS's Avatar
TWS
Default Re: Need LT1 cam advice
To have a good chance of passing emissions, I would go with moderate lift and an LSA of 114 or greater. This will avoid spitting out raw fuel like my comp cam does at idle (112 LSA, so I have overlap). It will also idle smoother than mine does.
Call comp cams's tech line. They are usually very cool and will give you better advice than I can.
Old Jul 22, 2003 | 05:34 PM
Gangly's Avatar
LT4 hot cam...awesome cam for mild application with no headwork
Old Jul 28, 2003 | 07:54 PM
Can an LT4 hot cam pass the sniffer test with a good tune and a cat?
Old Jul 31, 2003 | 07:36 PM
Oh I don't know about that...I'd take my chances with your advice before theirs because...the two times I talked with Comp selecting my LS1 cam they insisted a cam with more than .540 lift could not physically fit in an LS1 engine...also say 300cfm was very poor flow for LS1 heads and the numbers should be much higher.. ..the jerks I talked too were pretty much idiots.
Old Aug 1, 2003 | 03:08 PM
Gangly's Avatar
stock tune and cats will easily pass emissions with a LT4 hot cam. Many people have yanked the entire emissions equipment including cats and still passed emissions with the stock tuning and stock cam. i have heard of only a few LT4 Hotcam cars that have passed with no airpump, EGR, or Cats, but with stock tuning.
Old Aug 6, 2003 | 12:23 AM
Gangly thanks for the info!
Old Aug 7, 2003 | 11:58 PM
someday's Avatar
try the comp CC304 cam, 210/220-.500/.510-114... should pass emissions and run on stock tuning...
Old Aug 10, 2003 | 09:46 PM
96WS.6's Avatar
I have a 220/224 544/544 custom cam from Reed Cams in Stockbridge,Ga. It counts them off pretty good and passes GA emissions.
