Timing chain set?
Old Mar 8, 2008 | 07:15 AM
azboostin's Avatar
Default Timing chain set?
Can I use a regular sbc timing chain set or does it have to be specific for lt1? what is the difference if so
Old Mar 8, 2008 | 03:12 PM
Mojave's Avatar
If you use an SBC set, you have to use an electric water pump. If you still have a stock water pump, must use LT1 specific set. The difference is the teeth on the back of the cam gear that drive the water pump: LT1 has them and SBC doesn't.
