Extrude Hone LT4 or LT1 Intake Manifold?
Would like to hear from anyone who has actually sent their LTx intake out for Extrude Hone porting. What was your experience and what kind of gains did it bring?
I am NOT looking for opinions or "I heard about some guy once..." I would like to hear from the person who actually did it or if it was someone that you know very well and you know for sure what the results were.
Thanks in advance!
Thanks in advance!
I had a LT4 intake sent out to be extrude honed, but I cant tell you about any gains. I did the whole top-end (H/C/I) at the same time, so no back to back real world results. I can say this though... it looked really nice inside that intake!
Take a look at my sig for HP results.
I would imagine that the Extrude Hone played a positive role.
Sending a PM.
Ray, looks like you are preparing to blow my doors off at LTx.
I have thought and talked about doing a single plane. No time and $ to change my combo so radically before the shootout, but it is an option I might pursue later. I'll give you a call soon to see how you like yours. I'll probably get to experience it first hand from the other lane.
Guest
Posts: n/a
here is a vid from a buddies car that is running the same setup...this was just a 100 shot
http://youtube.com/watch?v=RuKiVh1WYbc
he went 10.96 @ 122 on motor.
Major Mods:
383cid, out of the box AFR 195's, 246/254 .6xx/.5xx Hydraulic roller, Edelbrock Vic-E, Nitrous Outlet Elbow, TH350, 12 bolt, 3.73, 28" tires, 3350# raceweight.
Only dyno'd 414rwhp through the TH350 and a 4000 stall
A single plane is probably in my future regardless. Just not in the near future.
I remember getting Tony to help me on mine back in the day, too bad I never got to use it.
That car leaves hard on the spray. Very nice.
I am real close to his motor times (me also on motor). If I could hook just a little better...
Ran an 11.15 @ 121.58 on a 1.57 60' last night on the very first pass. Then the track went away and I didn't hook for **** the rest of the night.
I have a question about the single plane... How well does the single plane perform during normal street driving. I mean, doe it perform like a carbed intake and not have any nuts until you get the power going? Or since the blades are in a plenum and the injectors are donw low, does it work like a usual EFI setup.
I guess I want to know what level you need to achieve before you would want a single plane. I mean, LE#2 heads and cam at a minimum or what?
Chris
Chris
