Can I delete torque arm?
"This system is a complete replacement of the stock suspension. It allows you to remove that bulky torque arm and replaces it with a double ladder bar conversion. This system not only allows you to transfer more torque directly to the tires but also gives you a suspension that actually works. The new suspension absorbs the bumps and vibration from the road and gives you the smoothest ride possible." (Taken from G-Force's web site)
That statement has to be one of the dumbest that I have ever read in regards to torque arm suspensions.
http://www.jegs.com/i/Lakewood/620/21700/10002/-1
the arm is im the stock location and the little tab gos on w the shock so you can guss the rest
Spohn also makes a crossmember with a torque arm attachment that would work with you th400. May be an even better choice.
