Question for you LT1 guys.
so ya, i wouldn't be able to afford them anyway.
- Thick decks
- Two different runner sizes. Like you have for the LS heads to support a variety of combos
- Amazing flow numbers
- Available with different rocker stud setups
- Changed valve angles like you have for the LS heads. Even a few degrees would be nice.
I'm no LT1 expert, but that's what I'd like to see out of a revised LT1 head. You did everything right with your LS heads, now it's time to use what you learned there and market it towards the LT1 crowd too. You could have the market cornered if you put out a head with better valve angles that would just bolt up.
what about the reverse flow cooling guys? how about ditching it?
What I would like to see...
- Various chamber sizes
- Large runner length, say one head at 210 and another around 230-240'ish
- Thick deck
- Pre-drilled for SBC intake bolt pattern, along with LT1/4 pattern
- 18 degree valve angle (or better), without having to use different headers and rockers
- Big flow numbers 300+
Not alot of people want to switch over to a converted 18 degree SBC head due to all the additional cost. I have $1500+ wrapped up in my headers and Y-pipe, it wouldn't be worthwhile to run your heads if have to ditch all that money.
For the love of all that's holy... CAN SOMBODY MAKE A BETTER INAKE!!
Brodix already makes a head like this for a Gen1, standard valvetrain and headers work on them.
THAT would be cool.
David
62cc chamber
195cc Intake runner
2.02 intake valve
1.60 exhaust valve
OTB the head has a spring good up to .600" lift
Ferrea 6000 series valves
This head as cast the way you see it will support around 500 HP naturally aspirated.
I am asking what other improvements would you like to see to make it a better head for you guy?
Your current heads don't offer any real performance for the dollar over a set of reworked stockers (in capable hands of course). All the after market MFG's keep putting out crap products for the LT1/4's, that are a half baby step above stock. We NEED/WANT something that's a leap forward.
We have all been saying this for years, but none of the MFG's seem to listen. They just go and design another set of heads (or any performance part for that matter) for the LS1 market. How many different style/type heads can you buy for a LS1/2/3... what, 40 billion or so!
Where did I put that brick wall... I need to smash my head into it!
What would be neat is, take a sheetmetal Hogans or the like and CAST it. We need more plenum volume and runner length.
OR a ready to bolt on Vic Jr type setup complete with elbow for our style throttlebody. Instead of having to do like Tony and most others, including me, buying stuff from 10 different places to get it together.
David
62cc chamber
195cc Intake runner
2.02 intake valve
1.60 exhaust valve
In case you have not noticed, on this board AND Camaroz28.com the LT1 world is blowing up right now, we are starting it up OURSELVES because no one has come to our aid.
Our OWN LT1 shootout has been scheduled in Kansas, MANY VERY nice cars have been finished here as of late...these cars WILL show the LT1's potential at that race. And when this happens the market will blow up. Guys are running mid 11's on STOCK PARTS, give us some good **** and watch what happens.
People love these cars...get on the bandwagon, be the innovators here.
David
- Thick deck
Maybe the only truely good idea I have seen sofar is a small chamber. Getting harder and harder to find good OEM cores for porting.
