Question for you LT1 guys.
If you want to sell these heads they need to be more cost effective than ported stockers. Right now i wouldnt even consider Trick Flow heads because they require milling ON TOP of the price i would have to pay to get them in the first place. If im going to pay someone for headwork... i might as well just have them port my stockers!
You will have a winner if you can achieve the following three things:
-Ready to go out of the box (54cc chamber)
-Affordable
-substantially out flow stock heads
There is not a head that does this on the market right now to my knowledge. Your head is only cost efficient for people with boost or strokers. It is not cost efficient at all for naturally aspirated stock displacement builds. I would also like to see a completely new head.
Heck, if you wanted to do something easy you could just clone iron LT1 heads and sell them in aluminum form - but that wouldnt be good enough for most people here.
A Gen1-2 head has saimesed(sp?) runners.
Hell if we could get a real head ready to bolt on that was a REAL performer you guys would make a killing, out of the box and on the car. You already make a "as cast" LS1 head that works very well.....copy that idea into this head.
David
In case you have not noticed, on this board AND Camaroz28.com the LT1 world is blowing up right now, we are starting it up OURSELVES because no one has come to our aid.
Our OWN LT1 shootout has been scheduled in Kansas, MANY VERY nice cars have been finished here as of late...these cars WILL show the LT1's potential at that race. And when this happens the market will blow up. Guys are running mid 11's on STOCK PARTS, give us some good **** and watch what happens.
People love these cars...get on the bandwagon, be the innovators here.
David
I was showing what the heads currently offer. If you read some of the past posts you will see other guys asking for a 2.02 intake valve and a spring that would handle .600" lift. I was stating the facts that the heads already have the springs and the 2.02 valves.
I was simply stating facts on the current head offered. The reson for this post was to get input from you guys on what you would like to see in a LT1 head.
a few chamber sizes to choose from. we really need a small chambered head thats close to stock so we dont have to get pistons made to keep our compression up. the first step that 99.9% of use do is a heads and cam setup. that right there leaves every aftermarket head out. you give us that option and you will have them flying off the shelves.
bigger intake runners or options of 2 different sizes.
a different valve angle, even just a few degrees, and still alow everything to bolt up.
make them ready to rip right out of the box but still have room to port.
Total Engine Airflow (330-634-2155)
Offers either a 200cc or a 218cc LT1 head based off our casting.
http://totalengineairflow.com/products/gmhead/gmlt1/
Advanced Induction (704-907-4341)
Offers either a 200cc or a 215cc head based off of our casting.
http://www.advancedinduction.com/AiProductsLTx.html
For me to sell your products I NEED a 54-56cc chamber. If Smaller to allow porting and chamber molding would be even better. To small a chamber is easy to deal with but when you start with one that is already to big you are screwed. Once you cover this any of your other CNC programs should work great!
Now if you came out with a set of 15-18* heads i would be all over it also as i have a Hogans intake sitting here ready to go!
Many guys run NA, and the huge chambers on the TF's as they stand now are too much of a hit on the compression ratio. That is a huge reason why most just try to get their stockers ported instead.
. What I would like to see...
- Various chamber sizes
- Large runner length, say one head at 210 and another around 230-240'ish
- Thick deck
- Pre-drilled for SBC intake bolt pattern, along with LT1/4 pattern
- 18 degree valve angle (or better), without having to use different headers and rockers
- Big flow numbers 300+
Not alot of people want to switch over to a converted 18 degree SBC head due to all the additional cost. I have $1500+ wrapped up in my headers and Y-pipe, it wouldn't be worthwhile to run your heads if have to ditch all that money.
For the love of all that's holy... CAN SOMBODY MAKE A BETTER INAKE!!
This is a set of stock castings. Notice any thing un-usual?
You guys think I run two different kinds of rockers for looks? Half of them are offset .150 to clear the bigger ports we welded into the stock heads!
STOCK Modified Castings and 210CC runners with 54cc chambers.
Trickflow give us some thing like this for an entry level and you are golden!
Good things have been listed:
We need 18* availability
52-62cc heads, offer them in "as cast bare" and in various stages to fully cnc'd etc. I know you say springs good to .600 lift, 600 on an old school roller is different from a new style grind 600 and from a solid 600.
availability of LARGE valves in the large chambered heads. 2.05/2.08 or so.
Offer it in perimeter valve cover and center bolt patterns.
i know i'm about to be at the potential for the heads I have so I'm ready to ditch them and upgrade and I want to go big.
