Question for you LT1 guys.
Old Mar 10, 2008 | 03:59 PM
TrickFlowTech's Avatar
LS1Tech Sponsor
Default Question for you LT1 guys.
Hypothetically speaking here, if Trick Flow where to come out with a "NEW" LT1 head, what features would you guys like to see?
__________________
Old Mar 10, 2008 | 04:06 PM
kahunaking's Avatar
I just ordered your LT1 assembled heads a couple weeks back and the only thing I would really ask for would be a 54cc chamber so that I dont have to run a domed piston for high compression.
Old Mar 10, 2008 | 04:15 PM
ThoR294's Avatar
we need a new intake.
Revelation Z28's Avatar
LS type ports, and ability to run dual springs out of the box.
Old Mar 10, 2008 | 04:18 PM
kierstyn's Avatar
I guess most people would like to see an aftermarket head that would bolt-on without knocking down the compression for once! I would like to see that and one that would flow like some of the stock ported heads out there but still have enough meat to be ported futher if needed. If thats possible you could offer a cnc'd version also.
Old Mar 10, 2008 | 04:48 PM
blackz6sp's Avatar
/\ X2!!
Old Mar 10, 2008 | 04:55 PM
JoeliusZ28's Avatar
x2 to that. if you could do it using LS style header ports (so you could use LS1 headers perhaps??) that would work to. Either way, heads are where the LT1 < LS1, you guys can change that
Id just like to see a nice aluminum head that flows well, and if anything UPs the compression slightly without having to do ANY work. 11:1 on a stock bottom end would be nice. Just ready to go out of the box.
Old Mar 10, 2008 | 04:56 PM
StealthFormula's Avatar
Originally Posted by blackz6sp
/\ X2!!
x3!!!
Old Mar 10, 2008 | 05:01 PM
gold98Z28's Avatar
yeah new intake to go with, smaller chambers, and cnc
Old Mar 10, 2008 | 05:17 PM
The Engineer's Avatar
54cc chambers (a must), intake runners in the 210 range, possibly slightly larger D-port exhausts, valves/springs that will handle an HR in the .600+ lift range, 2.02 Int/1.60 Ext valves.
An improved design EFI port-matched bolt-on intake, LT style "without" SBC water passages.
Next we need and aftermarket LTX block that can be bored and stroked to 430 CID.
WD
Old Mar 10, 2008 | 05:29 PM
MEAN LT1's Avatar
54cc chambers and upgraded ports would be nice.
Old Mar 10, 2008 | 06:07 PM
TheBlackZ28's Avatar
WD
I 110% agree with him. nothing could be better said sir.......
Old Mar 10, 2008 | 07:35 PM
buffman's Avatar
^^ +2 to the above.
Old Mar 10, 2008 | 07:57 PM
Biggin'89's Avatar
The only problem is the spacing on the lsx heads, its not 1 2 1 like ours, they are evenly spaced. So then not only would you need the heads and intake but you would need a custom cam that would swap the position of the intake and exhaust to match the lsx heads. So the way I see it not many people would jump at that b/c of all the componets involved in the swap
Old Mar 10, 2008 | 08:28 PM
Formula350's Avatar
54cc as said, dual spring-ability as said, biggest valves you can stick in while keeping the low cc (2.00 1.58ish? 1.60 ideally), bigger exhaust cfm since exhaust flow is a bit of an issue I hear on our LT1s (I don't know though).
Old Mar 10, 2008 | 09:15 PM
Pro_built7's Avatar
WD
YES !
X 10
no seriously, I don't understand why the aftermarket has dropped the LT1, I mean if only someone were to comeout with some wicked heads, and a better intake !!!!!!!!!!!!! they would make some serious coin. I'd be in for sure.
but no... its all LS now......
Old Mar 10, 2008 | 10:35 PM
JoeliusZ28's Avatar
WD
+3
huh??? I dont see what re-routing exhaust ports has anything to do with the cam? LS1 head ports look like | | | | whereas SBC are /\/\ You could evenly space exhaust ports without changing the intake. If the intake port spacing was changed, i guess i could see all that. but you make a good point. Im not engineer. I couldnt tell you if it would be optimal or not. I would actually rather have a traditional style for the interest of affordability anyway... more or less just thinking out loud.
Old Mar 10, 2008 | 10:41 PM
Formula350's Avatar
Yea, it's not fair the LSX guys get stuff like the 454cid option (and bigger I think on other combos)
http://www.worldcastings.com/prods_p...0_001_more.htm
Old Mar 10, 2008 | 10:54 PM
gold98Z28's Avatar
+3
stop and think about what the hell you are saying, if you move the exhaust ports you have to move the exhaust valves, now they are on top of where the intake valves need to be, so you have to put them where the exhaust was, so the intake has to go to the intake valve so has to be compleatly differant now.....now that everything is in differant spot, how they gonna work? the cam lobes have to line up with the corresponding valves, so unless you had a single pattern cam you would now need a custom grind.
Old Mar 10, 2008 | 10:58 PM
JoeliusZ28's Avatar
guess that didnt occur to me. LS1 springs looked to be in the same spot, guess i just never looked at them side by side. mah bad rocko.
Also there are heads out there that run rockers on an angle
either way. stupid idea. let it be lol
