Aftermarket heats
Chris
Chris
performance generally=less mileage
Cars run on gas and air
the more air you stuff into an engine the more gas it takes to combust
go ahead and buy AFRs....some of the most expensive heads on the market in order to MAYBE save yourself a few pennies at the pump. way to use your brain
and id like to hear the phone call when you call afr and tell them your looking for some heads to get good gas mileage
Chris
Last edited by seawalkersee; Mar 14, 2008 at 04:11 PM. Reason: Had to delete some stuff that may look bad...
I don't think any one is trying to be offensive towards you here, but I mean cummon. This is a v8 performance sight dealing in power oriented discussions that rarely if even ever have nothing to do with economy. I know what everyone is trying to say to you, it's just some cracks don't take it to heart.
Having said that I don't understand why your going the route you are with the v8 power. Maybe a import with forced induction or motorcycle is an idea you may consider. The smaller displacements will certainly burn less fuel.
I'm sure you can do it if you realy want and don't let any one discurage you, but I don't know who would have that kind of info on what your going to do and how much do you want to spend?
If effeciency=gas mileage like you are implying then it sounds to me like your are suggesting to bolt on heads to get better fuel mileage and you didnt like the answer of people who tried to tell you that there would be little to no fuel mileage gains because that is not the point of an aftermarket head. You then decide to whine about searching for some reason.....
Chris
If you want to sucessfully mod your car you will need to learn that reputations are maybe MORE often bought than earned.
If you want to buy used AFRs a friend is going to be selling a TPIS ported set, so he can put Advanced Induction ported stock castings on the car, because the Advanced Induction ported stock heads are a BETTER head based on results not magazine articles, not outdated info from someone racing 20 years ago, not inexperianced kids on the internet.
Off road pipe
Catback
Underdrive pullies
CAI
MSD or similar ignition box
Possibly a tune.
All of my cars in the past got BETTER mileage with JUST those mods.
You go PAST those mods above and it goes down...and we all know why.
I had two 5.0 Mustangs, even with the mods above AND a 3.73 gear they came close to 30 mpg on the HWY....AND ran in the 13's. But that was back when the speed limit was 55, 70 was hauling ***...alot different now.
David
Gears often help milage as stock setup are often on the verge of lugging the motor. 1500rpms on the highway is NOT a good thing.
