engine removal question
Old Mar 17, 2008 | 07:11 AM
hanner74's Avatar
Default engine removal question
I have been told by a local F-body guy that to remove the LT1engine from my 96 TA I must take it out the bottom with the transmission, because the tranny bolds are next to impossible to get to. I have had to do this on a car before, but didn't think my TA would be like that. Is this true? and if so how the $*%# am I gonna do my cam swap without a hoist. Please tell me i can pull the motor out the top with a cherry picker. lol!
Old Mar 17, 2008 | 07:17 AM
James Montigny's Avatar
You can pull it out the top, but it's a pain.
I find the bottom much easier and it can be done without a hoist.
http://www.michiganspeed.com/enginepull/index.html
Old Mar 17, 2008 | 07:31 AM
bigbadblack93z's Avatar
do the swap in the car? what else do you have going on that you need to pull it?
Old Mar 17, 2008 | 08:08 AM
hanner74's Avatar
Default ??
I am doing heads and cam, i need to pull the engine to swap cams
Old Mar 17, 2008 | 08:11 AM
gatorhead's Avatar
Uh.........no you don't lol
Old Mar 17, 2008 | 08:12 AM
hanner74's Avatar
Default ??
oh and Long Tube Headers
Old Mar 17, 2008 | 08:14 AM
gatorhead's Avatar
Both can be done in the car, and I would pay to see you do LT's with the motor out then put it back in from the top
Do your homework and read up, use the search feature.
Old Mar 17, 2008 | 08:15 AM
You don't HAVE to, but it sure will make your life easier.
The time saved in fighting things you can't reach or see easily justifies the 2 hours it takes to drop
the motor out the bottom.
hanner74's Avatar
Default How?
how would it be possible to swap cams without pullin the motor, even with the bumper off and radiator out, etc. i still cant see there bein any room, but if there is a way i guess i would be interested to know
Old Mar 17, 2008 | 08:23 AM
http://shbox.com/ci/cam_removal.html
or
http://www.zmydust.com/headsandcam.html (incomplete, but great pics)
or
http://www.fierolt1.com/lt1_CamHeadinstall.htm
Old Mar 17, 2008 | 08:33 AM
hanner74's Avatar
Default thanks
thanks for the links
