need a part number for a bleeder hose
Old Mar 17, 2008 | 07:48 PM
KriegerEhre's Avatar
Default need a part number for a bleeder hose
as it says in the title, need to know the part number for the hose with the bleeder screw on it - the complete metal/rubber hose that bolts from what looks the heater core to the waterpump - it's rotted out and needs to be replaced before it leaks my opti to death!
Old Mar 18, 2008 | 01:17 AM
bump, anyone? - it's the hose that goes on the top left hand side if it's broken it leaks right down twords the sensor on the opti. . .half metal/half rubber has the bleeder screw in it. . .need a new one this ones rotted out!
Old Mar 18, 2008 | 01:29 AM
porksoda's Avatar
This one? http://shbox.com/1/bleeders.jpg
Old Mar 18, 2008 | 01:31 AM
yeah the one closest to the alt!! i dont have a screw on the thermstat!
Old Mar 18, 2008 | 01:41 AM
porksoda's Avatar
I don't know if you can buy just the tube but the hole assembly is 10261147.
Here is a diagram so you can see the individual part numbers. But I think all you need is 3-7. http://shbox.com/1/heater_hoses.jpg
Old Mar 18, 2008 | 01:56 AM
94m6Z28's Avatar
they no longer make that tube. ive checked when mine went a few days ago. u need replaced the hole line. becuse
A) they dont make that part
B) as far as i know, u cant re-do pressure fittings on cooling lines
it sucks ^*^%, i know...but good thing u cought it befor it nuked your opti like mine did...
Old Mar 18, 2008 | 01:57 AM
holy crap thats expensive (looked it up) alright - yeah i figured it would be the whole peice. . .was hoping it would be like 50bux or something oh well thanks for the number!
it rotted and started to crack and ended up cracking a little hole that spewed out when it got to mid temp - so i cut it a little short when i cut it everything looked completely rotted inside, i'm worried about it seems to be holding but but i cut it really short and wanted to replace this soon! thanks guys. . .
Old Mar 18, 2008 | 02:01 AM
porksoda's Avatar
Yea it's like $80. Check with Scoggin Dickey. After all they are in your town and maybe they will hook it up! They are also a sponsor so throw out ls1tech when you call them or PM them.
Old Mar 18, 2008 | 02:06 AM
porksoda's Avatar
https://ls1tech.com/forums/member.php?u=3451
I'm like a copy and paste god!
