Trouble with cammed lt1
And for what its worth, the car went through a foot puddle in July with the stock motor, but this is the same maf and filter that got soaked, car hydro locked and snapped a stock rod..
You might already know all that but I figured I'd throw out a different opinion. I had a PCMfor less tune when I had the Hotcam kit and it was very rich. Pulled the plugs to verify it was rich.
If the CTS checks out ok, since you already have the scanner hooked up you can look at the rest of the data.
p0100
p0336
p0500
p1351
p1533
p1652
And the bank 1 sensor is reading 104mv with the car off, where's the bank 2 is reading 425mv... cars off with open headers again...
Any ideas why shes running so pig rich? Could it be the MAF? I know I have the code for the maf, p0100 but isn't that just effect closed loop?
Im gonna check fuel pressure friday when I get some time next, see if I kinked the return line or the FPR is fudged up.... Im really at a loss at this time..
Does the MAF do anything in open loop?
