Gears?
Old Mar 19, 2008 | 01:46 PM
Huff035's Avatar
Default Gears?
I'm pretty sure that my T/A has 2.73's in it, well at least thats what I have been told. I was just wondering if I should go to maybe 3.73's and how much of a P.I.T.A. is it to change them.
Thanks,
Old Mar 19, 2008 | 01:48 PM
infinitebird's Avatar
It's fairly involved and I would not recommend doing it yourself if you do not know what you are doing. You need special tools to align them properly.
Old Mar 19, 2008 | 02:56 PM
MonmouthCtyLS7's Avatar
If u dont know what your doing dont try it...Gear Install isnt that expensive
Old Mar 19, 2008 | 03:10 PM
StealthFormula's Avatar
I would definetly upgrade to some 3.73's and like said I would have them installed professionally. It is very involved and if not set up correctly will cause problems.
Old Mar 19, 2008 | 09:58 PM
Huff035's Avatar
anybody have an idea of how much its goin to run me?
Old Mar 19, 2008 | 10:41 PM
around $300-400
Old Mar 20, 2008 | 02:27 AM
squeals99's Avatar
ya i got quoted for install from my neighbor that owns a tranny shop $200 for install, not including the price of the gears and shims and all that other stuff that would prob. need freshened up in there
Old Mar 20, 2008 | 09:08 AM
Razor_Blade's Avatar
That's not a bad price. Another alternative would be to keep you eyes out for another rear end that already has 3.73 gears. I bought one a while back for only $250. Doing this would also allow you to have your old rear for a spare.
Old Mar 20, 2008 | 09:59 AM
James Montigny's Avatar
2-4 hours at the shop rate.
I had a dealer quote me $400 for gears and $600 for the install about 9 years ago.
A chain shop wanted $1100 for the install alone.
I private shop did it for $225 and I picked up the gears for $200 or so at the time from Jegs I think.
As long as they shim it right, you'll be golden.
If not, it will howl. If you catch it, you can fix it without a problem. If you let it wear in, you're SOL
Old Mar 20, 2008 | 02:35 PM
Formula350's Avatar
With your setup you need to keep in mind that your 2.73s won't allow you to buy normal 3.37s, you'll need to buy Series 2 carrier gears, or go and buy a Series 3 carrier (which 3.23+ use) and then buy Series 3 gears.
Old Mar 20, 2008 | 02:49 PM
Elliott's94Z's Avatar
Just got mine done and they ran me $500 installed. And you will need the new carrier as well..not sure what that runs though cause I had stock 3.23's.
Old Mar 20, 2008 | 04:21 PM
chevy94c's Avatar
I would have them installed professionally. 3.73 would be a good choice of gear. If you look in the glove box there will be a GU code. I forget the 2 codes numbers. I think GU2 2.73 GU5 3.23. I could be wrong.
Old Mar 20, 2008 | 04:36 PM
Formula350's Avatar
He doesn't HAVE to get a new carrier, they make gears for 2.73 carriers.
GU2 is 2.73s, GU5 is 3.23 and GU6 is 3.42s
Old Mar 20, 2008 | 09:52 PM
I guess I've been mislead then..sweet
Old Mar 20, 2008 | 10:42 PM
Rambo06's Avatar
I own a speed shop in Oklahoma and I install gears on a regular basis and you would definitely want to have them professionally installed. I also stock many different kinds of gears weather you have a 2 or 3 series carrier I can sell you just about any ratio from 3.23 to 4.56 for around 145.00 a set plus shipping, and that goes for everyone.
Old Mar 20, 2008 | 11:12 PM
justatoy's Avatar
Just got mine back from the shop and they charged me 430 with tax.
Old Mar 20, 2008 | 11:37 PM
Rambo06's Avatar
Anyone that would like a set of gears or any other performance parts just shoot me a pm.
Old Mar 24, 2008 | 01:55 PM
Silver2000WS-6's Avatar
Do you have to buy a master install kit?
Old Mar 24, 2008 | 03:01 PM
Formula350's Avatar
Wouldn't be a bad idea. So you get all new bearings and stuff.
