These The Right Parts??
Old Mar 22, 2008 | 09:15 PM
94m6Z28's Avatar
Default These The Right Parts??
no one *lordco, mopac* seems to be able to get this right. so i thought id ask you guys, the ones who have done it so i can stop getting tosed around
injectors - 44#'s - accel pn 150844
http://www.accel-dfi.com/ProductDeta...&minselection=
fuel pump - 255 - holly pn 12-903
http://www.holley.com/12-903.asp
the fuel pump says it only goes upto 1992, will this work in a 94lt1?? is there a sertant pump i need??
will those injectors work, or is there a sertan style i need??
Old Mar 22, 2008 | 10:50 PM
wannabess's Avatar
The injectors look like they have the correct connection. The fuel pump is only for a 92 as a direct replacement. You can put it in your car if you cut up the wiring, but why do that when you can buy one that works w/o cutting up your stock wiring from racetronix. Also it's certain not sertan
Old Mar 22, 2008 | 11:42 PM
94m6Z28's Avatar
pft
for the racetronixs, im guessing i need to order off of here? and that no place up here in BC*canada* is going to stock one
Old Mar 23, 2008 | 09:23 AM
wannabess's Avatar
Originally Posted by 94m6Z28
pft
racetronix.com
Old Mar 23, 2008 | 09:25 AM
Slvr00Bird's Avatar
Why are you bumping up the injectors? Got a head/cam package on the way??
Old Mar 23, 2008 | 09:33 AM
96capricemgr's Avatar
Accel's injectors were long garbage, DO NOT ue the yellow tops I mention it just incase someone ships you old stock.
The Holley pump will be the same basic Walbro pump as Racetronix sells but Racetronix offers a better kit so it is more complete and fits better, frankly I would look at injectors from them before the Accels too.
They have several dealers in Toronto and I think they may actually be in Canada themselves.
On the pumps you have to understand that all the available intank stuff is a Walbro pump with small differences, so don't get worked up over brand get the one that fits best, the Racetronix WITH WIRING UPGRADE.
Old Mar 23, 2008 | 11:41 AM
94m6Z28's Avatar
k, so no yellow top accel 44's
racetronixs pump. do i need the plug and play kit? or is it just an upgrade?? if its not a 100% must ill get it later when i plan on making more power
Old Mar 23, 2008 | 01:48 PM
Slvr00Bird's Avatar
Ohhhh I just noticed your sig... Injectors make since
